Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
tonneaucovered.com
Old 11-14-2011, 12:24 PM
Phillyeaglekgd Phillyeaglekgd is offline
Vehicle: 2007 Ram 1500 QC 4X4 SLT BH
Trim Level: SLT Big Horn
Color: Inferno Red Crystal Pearlcoat
Phillyeaglekgd is on a distinguished road
Default Where's the wiring?
I have an 07 1500 QC. I have my build sheet from Dodge and it shows that I DO have the towing package. I have all the extra coolers up front, tow/haul mode, and the 3.92 gears. When I bought the truck, it did not have a hitch or the 7-pin factory plug-in; it only had the 4-pin connector behind the bumper. I installed a hitch, and I have just been using the 4-pin connector. I guess this really isn't a "problem", it's just been on my mind. Where are the factory wires? Could they have been removed by the previous owner? Why would they do that? Is it worth buying the factory harness (I assume this is possible), or am I just missing something? Thanks for reading and any help is appreciated!
Old 11-14-2011, 02:39 PM
A lot of times the "towing package" wiring is encased in a plastic bag and thrown under a seat. This would include the harness adapter and a 7-pin connector. Mine was installed when I got my truck.
Let's see a pic of your back bumper, right around the license plate light area.
Old 11-14-2011, 11:18 PM
Here we go.
Old 11-14-2011, 11:26 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
WOW That's the first Ram I have ever seen with no trailer wiring plug beside the license plate. I just assumed that they all had it...with or without the towing package.
brad
Interested in one of my mods?
Old 12-02-2011, 05:32 PM
rambrute's Avatar
rambrute rambrute is offline
Vehicle: 2007 dodge ram
Trim Level: lonestar
Color: dark grey
Rep:30
rambrute is on a distinguished road
my 07 did not have it either i just bought aftermarket. and did my own wiring. works pretty good so far.
Old 12-02-2011, 07:45 PM
Stainless's Avatar
Stainless Stainless is offline
Vehicle: 2011 Dodge Ram
Color: Bright white
Rep:13
Stainless is on a distinguished road
Looks like someone didn't PDI your truck properly when new, cause its missing stuff if its supposed to have it.
Old 12-02-2011, 08:39 PM
Rep:2731
A lot of the Gen 2 & 3 just came with the 4 pin connector, that just hangs down like yours did or does
You can buy a 4 pin to 7 pin adapter
http://www.etrailer.com/dept-pg-Wiri..._and_Lead.aspx
Video of the installation process
http://www.etrailer.com/tv-wiring-in...dodge-ram.aspx
Have Fun
Old 12-04-2011, 08:09 PM
beermanjoe's Avatar
beermanjoe beermanjoe is offline
Vehicle: 2007 Ram
Rep:25
beermanjoe is on a distinguished road
If your not going to run the extra wires to the rear for a true 7 wire,just use it the way you have been. To pull something with electric brakes. You`ll have to run wires from the cab.
Old 12-06-2011, 02:13 AM
rambrute's Avatar
Color: dark grey
Rep:30
the wires terminate right behind the front left wheel well. i just ran the wire for the elec. brakes not for the charger i have the wire ran but not hooked up for the charger.
