MPG Improvement with Billet Tech Catch Can? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-14-2011, 09:24 PM
HeyBrownDog's Avatar
HeyBrownDog HeyBrownDog is offline
Vehicle: 2011 Dodge Ram Quad Cab 4x4
Rep:20
HeyBrownDog is on a distinguished road
Default MPG Improvement with Billet Tech Catch Can?
Does installing a catch can improve your MPG, power, both?
It's obvious the primary reason everyone is installing these catch cans is simply keeping the crap out of the intake, and gumming up the rest of the motor.
A quick Google search on the web leads me back to this forum, but also gas saver websites. Anyone seeing some improvement on MPG? Can't be hurting the MPG, but curious what everyone might be seeing any improvements in performance other than knowing what "didn't end up burning off in the motor.
Thanks!
Old 11-14-2011, 09:32 PM
nYmPhMoBiLe08's Avatar
nYmPhMoBiLe08 nYmPhMoBiLe08 is offline
Vehicle: 2008 Dodge Ram
Color: Metallic Gray
Rep:75
nYmPhMoBiLe08 will become famous soon enough
As far as i know it does nothing to performance or MPG but it does prevent your throttle body from getting oil in it which in the long run can rob performance and MPG
~Landon~
Current MODS: | Bilstein 5100's (Front) | Monroe Coil Overs (Rear) | Tow Mirrors | Husky Tool Box | Plasti-Dipped Badges/Gas Cap | 295/70/17" Nitto Trail Grapplers | 17X9" Fuel Boost Wheels | 3" DMH Cutout | RT Stripes \\ | WeatherTech Floor Liners |
Old 11-14-2011, 10:49 PM
No, it won't improve performance but it lets you keep the performance you have.
Old 11-15-2011, 12:34 AM
Rep:3347
Sorry, doesn't do anything for MPGs or performance, what it does is increase the reliability since you don't have all the oil vapour and blowby from the crank case being put into the intake manifold, landing on your valves and settling on the back of your throttlebody.
Old 11-15-2011, 12:50 AM
Rep:2968
Smog systems take excess oil & put it into the throttle body, hoping that it will get burnt up in the combustion chambers, ie: the pistons & spark plugs
as anyone with a half a brain knows, the gas engine combustion chamber does not get hot enough to burn oil, but someone convinced the politicians that it does
A glow plug system like what is in a diesel may burn it off, but never a gasoline engine with spark plugs
So we use a Catch Can to hold the excess oil so that the rest of the fuel system stays fairly clean
the engine builders do everything they can to keep oil below the piston rings & smog devices put oil on top of the piston, it does not make any sense at all
Old 11-15-2011, 09:49 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Technically it will do both (less oil in the mix gives more volume of air/fuel = more power). Also allows you to tune in more timing advance as the oil reduces octane level. These gains are minimal if any though, nothing really noticeable.
Sean
Old 11-15-2011, 04:22 PM
Rep:20
Thanks for the info guys.....good stuff. Makes sense to keep the Hemi running like new while she's only going 600 miles on her now.
Just ordered a new Bakflip G2 this morning for my truck, and looks like this mod /accessory just moved up a little higher on the priority list.
Old 11-15-2011, 05:06 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Catch cans are a great, easy mod that can only help your engine run it's best and last the longest!
Old 11-15-2011, 09:14 PM
LeroyJaxson's Avatar
LeroyJaxson LeroyJaxson is offline
Vehicle: 2011 Ram 1500
Trim Level: Express 4x2
Color: mineral grey
LeroyJaxson is on a distinguished road
Anyone have pictures of their catch can setup. I would like to see what has been done before I do it?
Old 11-15-2011, 11:22 PM
916Timmy's Avatar
Rep:1443
