Old 11-14-2011, 09:37 PM
billsfan60 billsfan60 is offline
Vehicle: 2000 dodge ram
Trim Level: slt laramie
Color: gold
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
billsfan60 is on a distinguished road
Default Oil Pressure Sender Woes
Good Evening all. First time here and I'm bringing a problem with me. Have a 2000 1500 with a 5.9 V8 with an intermitent oil light and zero pressure on my gauge that comes and goes. Decided to start with replacing the sender to see if that would fix it. After an hour of fighting with the connector I've given up. I can't seem to get the thing off the old switch and buried back in the engine bay I can't see what's keeping it on there. Any suggestions?
Old 11-15-2011, 12:52 PM
moparornocar72's Avatar
Rep:630
i believe there is a slide clip on the conector that prevents it from moving, slide it over and then it should slide off, dodge/chrysler's design of the oil sending unit isn't the best, eventually the seal gives out and oil shoots into the sensor and kills it. jeeps also used to do this.
14.268 @ 95 MPH Full Trim
