Old 04-28-2013, 11:59 PM
Txhillbilly's Avatar
Txhillbilly Txhillbilly is offline
Vehicle: 2012 Dodge PowerWagon
Rep:41
Txhillbilly is on a distinguished road
Originally Posted by scrappy View Post
I had a 3/4 ton truck with a 6" short arm Fabtech kit and I HATED it!, the truck rode WORSE than any STOCK truck out there! I spent nearly $2K trying to make it ride better. changing to a longarm kit, upgrading to Bilstein 5100/5150's, and upgraded steering system/ damper. all that improved things quite a bit BUT it still rode WORSE than my 1 ton DUALLY! and pretty much across the board performs worse than a stock 3/4 ton, both on AND OFFROAD! and lifting the truck NEUTERED its capability for towing. I couldn't pull a 5th wheel AT ALL, a gooseneck is marginal, and by the time the hitch is low enough to pull a tag, trailer, the truck couldn't pull anything hardly! It WASN't that the truck didn't have the puwer to do it, the lift, wheels, and tires made it physically too tall. i had a 6" drop hitch and the hitch is still too tall for most trailers and was weight limited to ONLY 3500# Finally, asking a truck to pull those weights with lift, wheels, and tires problematic at BEST!
Granted,My PW rides a little bit stiffer than it did stock,but not by much. My 2006 3500 Megacab dually 4x4 rode just as stiff as the PW does now,and it was only leveled,but I ran 35" rubber on it also.
The PW has no problem pulling my trailer,and if I needed to pull a gooseneck anymore,I'd still have the dually.
If the PW was a daily driver,I would've probably went with a long arm setup,but I only drive it a couple days a month when I'm off work. It rides a lot smoother than my 18 wheeler does on the terrain that I drive on at work.
I have nothing against the lifts that are out there that make these HD 3/4 - 1 ton trucks ride smooth,but then the suspension castrates the hauling/towing capacity of the truck,so you might as well buy a 1/2 ton truck and lift it if you want a truck that rides like a car.
