Old 11-15-2011, 01:55 PM
pt145ss pt145ss is offline
Vehicle: 2004 Dodge Ram 1500
pt145ss is on a distinguished road
Default Leveling Kit Questions
Hello All, New to the forum.
I'm sure this has been discussed here before but I just could not seem to find what i was looking for when utilizing the search option.
My son has a 2004 Dodge Ram 1500 (2wd) Hemi and I'm looking to buy him a leveling kit as one of his Christmas gifts. From what I could see on the net there appears to be two kinds of kits, a torsion bar key and/or the kind that goes over the coil. So my questions are, which type is better and are there any recommendations on brand and/or place to get them?
Any help will be greatly appreciated.
Thanks in advance.
Old 11-15-2011, 02:52 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
They only used torsion bars on 4x4 so that options out.
Your options are a coil spacer or a leveling spring. That decesion can be made by your budget and how much lift your looking for.
Measure from the center of the wheel to the lip of the fender in the front and bac, the difference between the two will tell you how much lift you need to be level.
I think your best options for a 2wd are a spacer from fatbobsgarage.com or rough country sells a 3" "lift kit" (3" springs for the front 1" block for the rear). I think the later is the better deal but it's somewhere around $300 I think
Old 11-16-2011, 09:28 AM
I appreciate the info. I will most likely go with a coil spacer because the lift is mostly for cosmetic purposes.
I was reading some DIY stuff on installing a spacer and found conflicting information. Some say a spring compressor is necessary and others say that it is not necessary. Can any one point me to a Ram specific DIY for the spacer?
Thanks.
Old 11-16-2011, 10:23 AM
snrusnak's Avatar
snrusnak snrusnak is online now
Rep:1385
Not to turn you away from this, but there are several threads of people having issues with the spacer kits. I don't know if the 2wd's have the issues, but just be aware of it and make sure you do a lot of research.
Sean
Old 11-16-2011, 10:44 AM
Color: Mineral Gray
Rep:177
With 2wd drives there is a chance of causing premature ball joint wear. Some people have problems Wwith their ball joints because of the angles they are at at some heights.
I used a spring compressor and had to put a bottle jack between the axle to get the spring and spacer back in. You can pick some up at harbor freight cheap. They can be very dangerous, I do t like to crank them down anymore then I need too
Old 11-17-2011, 07:47 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
I installed a 2" spacer from Fat Bobs Garage at the beginning of this year and havent had any problems. I didnt use a spring compressor, I simply placed a jack under lower control arm, busted upper ball joint and tie rod loose, and lowered jack all the way. You will need that jack to put it all back together. I have done both my 02 and my uncles 04 and didnt see the need for a spring compressor, just put the truck on jackstands as high as it will go and you shouldnt have any problems.
Before
After
Sure it'll suck, but it'll make you a man
Old 11-27-2011, 09:45 AM
mikeb33's Avatar
mikeb33 mikeb33 is offline
Vehicle: 2012 1500 CC Express 4WD
Trim Level: Crew Cab Express
Rep:14
mikeb33 is on a distinguished road
Are you sure he wants to go up? Some people level by lowering the rear. Especially 2WD types.
2012 Express CC Black 4WD 3.92 Posi, Bedrug, Backflip G2, Cut rear springs, V6 fan mod, 180 thermo, Diablo Sport
Old 10-21-2012, 02:16 AM
HamishHill HamishHill is offline
Vehicle: 2004 Ram 1500 ST
Color: Blue
HamishHill is on a distinguished road
Default levelling
Mike is right, I looked at bringing my 04 up in the nose but now thinking ill drop the rear.
