Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 11-15-2011, 08:17 PM
hemipoweredram hemipoweredram is offline
Vehicle: 2005 Ram Hemi
Color: burgandy
hemipoweredram is on a distinguished road
Default Looking to buy 99 Diesel, What to look for?
looking at a 1999 5.9 cummins diesel, rebuilt transmission, 6 inch lift kit, 5 inch exhaust, is there any common problems i should keep an eye out for on this thing? its got 323k kms or just over 200000 miles, any help greatly appreciated thanks!
Old 11-15-2011, 10:12 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I would be cautious of a truck like that. You never know who installed the lift or how the truck was treated.
Have the front end checked by a mechanic, it can cost you a ton in the long run.
The motor should easily have another 100k miles in it but the truck still has 200k on it, parts are going to need replaced.
Check to see if the motor is a 53 block. With that kind of miles it should be ok but there is a chance that it might be a repaired 53 block
Old 11-15-2011, 11:01 PM
Color: burgandy
how would i go about finding out the block info? would it be stamped somewhere?
Old 11-15-2011, 11:22 PM
Color: Mineral Gray
Rep:177
Left side of the block by the power steering pump just above the oil pan. Its stamped behind the injector pump, you will see a wiring harness right above it
Old 11-16-2011, 11:10 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Dont know about number thing. But ive been driving 24 ft straght truck's for 12 years with the 5.9 cummings. The main thing that we have had problem's with is lift pump, timeing cover leaking oil. Also fuel lines leak but I think that has something to do with them being cab overs. But the truck I have now is an 05 with 320,000 km on it its only went thru 1 lift pump, water pump. No oil leaking or fuel line issue and I do both city and highway year round with engine running @1300 rpm about 4 to 6 hours a day (pto's). So in short if it was well cared for you should do ok.
Old 11-16-2011, 04:08 PM
Color: burgandy
thanks for the help guys
