Old 11-16-2011, 06:31 PM
Ryder2011's Avatar
Ryder2011 Ryder2011 is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Trim Level: se
Color: moca?
Ryder2011 is on a distinguished road
Default i tore it back apart !!
after all that,i tear the front end back off down to the timing chain cover and i put her back on TDC:...i find that when i remove the valve covers that the right camshaft gear is sittin about 10:00 o'clock and the left side is sittin about 01:00,so i take all this apart and keep the chains stabilized and move the cam gears (V8) back around to 12:00 and i put it all back together and torqued and that's when i dropped my 5/16 wrench down in the timing chain res...so i go ahead and take the water pump off and come to find out the bearings is gone in it,so i just LMAO and get on the phone and order the right kind of harmonic balancer puller for 90.00 and that was after i ordered a water pump,so i think the wrench saved my tail !!
Old 11-19-2011, 01:38 AM
Blackfire553 Blackfire553 is offline
Vehicle: 2000 durango
Blackfire553 is on a distinguished road
you can rotate the engine without taking the head off to get them both back at TDC
the left head was out of time on mine so i rotated the right head, the engine, the left head, the engine, and then both the heads.
Old 11-19-2011, 02:27 AM
Rep:2657
OMG, that brings back images i would rather forget
I once put an engine back together, then dropped the air cleaner lock nut down into a carburetor
Is it only out here that you can rent tools from Autozone & Orielys
