Old 11-27-2011, 10:50 AM
s2welee s2welee is offline
Vehicle: 2011 Dodge Ram 1500 SLT
s2welee is on a distinguished road
Default Tire Rotation Question
Sorry if this has been asked before, I searched but did not see anything.
I have a 1500 SLT Big Horn 4x2. I am at tire rotation time and I have a question about the pressure sensors. Since they show each tires inflation, how do I rotate and keep the correct tire showing in my dash readout? Is there an over-inflation re-learn that some other cars have? I hate to pay the dealer for such a simple task. Thanks guys.
Old 11-27-2011, 11:22 AM
Hedghawg71's Avatar
Hedghawg71 Hedghawg71 is offline
Vehicle: 2011 Dodge Ram Express
Rep:21
Hedghawg71 is on a distinguished road
They are sensors and the computer always knows, at least on my wife's truck anyways. She has had hers rotated every oil change and she is at 19K and some change. On mine the Express, they either don't come with them or mine is broke. Either way I hope I don't have them on mine.
Nothing a Hammer can't fix!
Old 11-27-2011, 11:24 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
I've rotate mine three times now and the EVIC always knows where each tire is. They must be coded to the tire/wheel so the EVIC knows how to display them.
Old 11-27-2011, 11:26 AM
Rep:4085
You should have them on your Express. If you don't have the EVIC where it displays the tire pressures, you won't notice anything unless one of the pressures is not right, then you'll just have the light on the dash that comes on.
Old 11-27-2011, 12:25 PM
Rec 26's Avatar
Rec 26 Rec 26 is offline
Location: El Paso, TX via Centereach, NY, Vieques, PR, and San Antonio, TX
Vehicle: 2014 RAM 3500 Crew Cab Dually
Trim Level: Tradesman
Color: Bright White Clear Coat
Rep:71
Rec 26 will become famous soon enough
Send a message via AIM to Rec 26 Send a message via MSN to Rec 26 Send a message via Yahoo to Rec 26
The value on your tires is the tire pressure sensor. As long as the tire is mounted, the system will recognize the tire.
2011 Ram 1500 Big Horn Quad Cab "SRT Hauler Mark I" (traded in)
2014 RAM 3500 Tradesman Crew Cab "SRT Hauler Mark III"
Old 11-27-2011, 12:40 PM
Rep:2657
On my original wheels & tires, i had a readout
the replacement wheels & tires just display a light when a tire is low, but i didn't go to the dealer to get the new TPMS programmed in
Old 11-27-2011, 12:42 PM
Rec 26's Avatar
Rep:71
I got two different sets of tires for my SRT8 and my SRT Hauler. I bought the correct value sensors for both sets and I've never had a problem nor did I have to go to the dealer and get them programed.
Are you sure you have the correct ones?
Old 11-27-2011, 12:57 PM
wbowyer wbowyer is offline
Color: Inferno Red
Rep:71
wbowyer will become famous soon enough
if you're pressure is low you'll get an indicator light and a message saying LOw TiRE. only "problem" is it doesn't tell you which tire.
Old 11-27-2011, 05:05 PM
Thanks guys. Just to be clear, I have the in dash readout that tells me the pressure of each tire, not just the little idiot light. I am just worried about those being mixed up (not really a problem but it would bug me)
Old 11-27-2011, 07:06 PM
Vehicle: 2012 Dodge Ram Sport
Rep:47
How are the sensors connected? How do they tell which tire are low and which one is low when you rotate them?
