Old 11-18-2011, 04:28 PM
MaRvO75 MaRvO75 is offline
Vehicle: 2004 slt quad cab 1500
Color: Almond
MaRvO75 is on a distinguished road
Default Bedrug... carpeted bedliner install opinion.
I am planning on buying a carpeted bedmat, but i have a spray n liner, will it install ok or do i have to remove the spray in liner?
Old 11-18-2011, 06:54 PM
MJGALLINARO MJGALLINARO is offline
Vehicle: 2011 RAM 1500 SPORT CREW CAB
Trim Level: SPORT
Color: WHITE
MJGALLINARO is on a distinguished road
You should be able to install the bedrug over the spray in liner. It may not fit 100% perfect and you may have to do some trimming of the foam on the underside of the rug depending on how thick the spray in lining was applied, but it is lot better than trying to remove the spray in lining.
Old 11-18-2011, 07:00 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Question is the bed rug is held down by velcro will the velcro strips stick to the bedliner if not then youll have a problem
Old 11-21-2011, 12:22 AM
gingrbredman's Avatar
gingrbredman gingrbredman is offline
Vehicle: 2011 Ram 1500 Crew Sport
Color: Deepwater Blue
Rep:89
gingrbredman will become famous soon enough
I doubt you would have to do any trimming. The spray in liner is not that thick that you would have issues. Under the bedrails can be tucked if necessary, and at the front and back, there is a little room to work with as well.
Love the bedrug!
Gusz 2011 RAM SPORT CC -Lockpick CHR550 -Hardwired Radar Detector - Custom Trailer Cam - -Fold a-Cover G4 - Bed Rug - Billet Shifter - Debadged - 18" Magnaflow - Custom Clear HID Projectors - LED Tailgate Bar - Custom Billet Badges -
Old 11-22-2011, 03:17 PM
Color: Almond
Man that looks so nice! Are there any bad things about the bed mats? Does it stay inplace as good as it says?
Old 11-22-2011, 04:29 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
Yes it does just not sure how well it will stick to a spray on liner
Old 11-22-2011, 05:10 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Bed rugs are very nice. Ran mine with a carpeted bed cover for a few years and it was like having a huge trunk. Ran the bedrug in a open bed for another 2 years when i took the cover off. Only negative for me was hauling landscapes debris as it took a bit to get all the pines and needles out afterwards but that was far few and between.
Old 11-22-2011, 06:05 PM
Ramsrule123's Avatar
Ramsrule123 Ramsrule123 is offline
Vehicle: 2011 cc 4x4
Trim Level: laramie
Color: bright white/gold
Rep:71
Ramsrule123 will become famous soon enough
did it w mine sticks fine, just prep it to be clean and a few more velcros on the corners will seal the deal, love it
"Honey I got a new mod, wanna see? Hey what's that face for?"
Old 11-22-2011, 06:14 PM
Color: Satin Orange
Rep:597
You can test the tailgate section with the provided Velco and if you feel that its not good enough then maybe try some industrial strength Velcro, but like others have said - Good prep is key.
Old 11-22-2011, 09:53 PM
HeyBrownDog's Avatar
HeyBrownDog HeyBrownDog is offline
Vehicle: 2011 Dodge Ram Quad Cab 4x4
Rep:20
HeyBrownDog is on a distinguished road
x2....just about to post the same question. I suspect the adhesion strips will not hold on the spray in bed liner. However, I also suspect enough friction that it might not slide around either. Short of grinding off the spray in liner to create a smooth surface, I can't see it working as good as the bare beds.
After Chrysler just charged me $450 for the spray in liner, not really interested in compromising the liner by grinding it away.
Let us know how you make out.
