Old 11-19-2011, 12:35 AM
Liphter Liphter is offline
Vehicle: 95 Dodge Ram 1500
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
Liphter is on a distinguished road
Default Rough runner after tune up
Alright fellas,
I've got a bit of a situation with my 95 1500 5.2L that I need some help with. The ol' gal has 196k+ and I'm restoring it for my son. I recently did a tune up...oil, grease, plugs, wires, rotor, cap and rear wheel speed sensor... Now it shutters and runs like shit!!? The plugs were worn and obviously old and the wires were worn as well as the cap and rotor... I must be missing something. Any suggestions would sure help!
Thanks ahead of time,
D
Old 11-19-2011, 02:15 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Crack any plugs putting them in?? Been there, done that...
Old 11-19-2011, 08:39 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Did you reset the PCM? Sounds silly but doesn't cost anything. After each tune up on mine (196k) if I read the codes it runs like doo doo. I have to pull the Neg cable, cycle the key once, re-attach the cable. Runs fine.
Old 11-19-2011, 09:07 AM
1tonwhitey's Avatar
1tonwhitey 1tonwhitey is offline
Vehicle: 2004 ram 2500
Color: slt laramie
1tonwhitey is on a distinguished road
Try some seafoam engine treatment.It might be clogged up with carbon..You put some in your gas and some in the intake hose usually from brake master .It really works well.But If it's never been done prepare for one hell of a smoke out.Youll be amazed at how much carbon will come out of the exhaust..
Old 11-19-2011, 09:26 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
All of those are great. Check all vacuum lines, deffenetly do computer trick you might have to teach that old dog some new tricks.
Old 11-19-2011, 09:46 AM
Thanks fellas. I'm gonna reset it and see what happens, is that the computer trick? If not I don't know what that is but sounds like something I should do.
Thanks again,
D
Old 11-19-2011, 10:18 AM
ramfam's Avatar
Trim Level: Base
Rep:21
That's the trick it will set the computer into limp mode and force it to re learn.
Old 11-21-2011, 11:58 AM
Alright fellas, I ran the reset last night...hoped like hell it would do the trick..and...nadda! Runs a bit better but still runnin really rough. Almost sounds like the timing is off or its missing a bit. The truck ran decent before the tune up but now it has a shudder or stutter when I drive it. Also, I noticed that when I gave it gas at idle it sounds like there is a leak or liquid swooshing sound from the passanger side somewhere but it was too dark out to see what the hell it was. Any help or ideas would help alot.
Thanks,
D
Old 11-21-2011, 03:43 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Sounds like you may have a vacuum hose disconnected somewhere.
Old 11-21-2011, 08:12 PM
Vehicle: 95
Rep:1776
I second that. Check the hoses. The fluid wooshing noise...probably just the coolant circulating in the heater core. When's the last time you listened to the truck and not the radio?
