Check engine light - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 11-19-2011, 12:16 PM
toddrod's Avatar
toddrod toddrod is offline
Vehicle: 2001 Dodge Ram
Color: Yellow
Rep:55
toddrod will become famous soon enough
Default Check engine light
Hey all, been a long time. The check engine light is on in my truck and I'm wondering if there is a way to source out what the problem is without the use of a code reader.
Old 11-19-2011, 12:21 PM
Try this:
1. Ignition switch off
2. Press and hold the trip reset knob
3. Turn the ignition switch to on but do not start.
4. Hold the reset knob for approx 10 seconds or until the word
CHEC appears in the display then release.
Be ready to write down some numbers. If I remember right, "999" means the check is done.
Old 11-19-2011, 12:58 PM
toddrod's Avatar
Color: Yellow
Rep:55
cool, thanks. I'll give it a go and see what happens
Old 11-19-2011, 08:06 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2014 1500 Eco diesel/1982 D150
Trim Level: Outdoorsman
Color: Deep cherry red
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:21
Will that work with all obd 2 trucks?
Old 11-19-2011, 08:26 PM
It should, ramfam. If it was an EVIC equipped truck the process is a bit different.
Old 11-19-2011, 11:57 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I am impressed!! Never knew that!!!
Old 11-20-2011, 03:05 PM
toddrod's Avatar
Color: Yellow
Rep:55
Alright, I did what maddog said and I think its all good. I never got any numbers indicating there was a problem, and my wife failed to mention that the engine light shut off while she was driving it the other day. I thought at least that the pcm would have stored the trouble code to be identified at a later time. Also, when it was doing its systems check I never really got a "999" indicating check complete, instead the proper mileage came up on the odometer after a few minutes. Could this also indicate that the system check was completed?
Old 11-22-2011, 10:02 AM
ramfam's Avatar
Rep:21
I tink it dose thats all mine will do once the gadges scroll arround and warning lights come back on.
Old 11-26-2011, 01:24 PM
toddrod's Avatar
Color: Yellow
Rep:55
Alright, the check engine light came on again so I tried maddog's method. Unfortunately, I got no readings so i turned the key to off. I dont know how I came up with the idea but I turned the key back to on (without turning the motor) and then off again. I did this three times and the odometer read p0138. Found out I have a faulty o2 sensor. Try what I did if your having problems sourcing a trouble code, it may help.
Old 11-26-2011, 01:54 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
That's cool that it did that, congrats on finding out the problem. For those with tuners you can also use it to read scan codes. It also works on other vehicles at least mine does, I just used my SC cortex tuner to scan our 2008 Mitsubishi Lancer. Was able to get three codes from it's PCM and determined that I have a faulty brake switch circuit. Just felt like throwing this out there, I was surprised it worked on another vehicle.
sales@revelperformance.com
