Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 11-26-2011, 02:30 PM
OK...that's the JTEC PCM method, which will also work.
1998-2002 (maybe more) Dodge trucks and Jeeps, put transmission in neutral, parking brake on, then do the key sequence 3 times ending with RUN.
Believe it or not, with some of the older PCM's, the first method I posted will work. It will also work with the 1999 - 2002 Caravan
Codes are displayed on the odometer.
On some cars, the codes will read out if the engine light is on - all you have to do is put the key into the RUN position.
Some time ago a guy posted up something about turning the truck on, putting it in reverse and backing up 3 feet...not sure if that works or not!
Old 11-26-2011, 02:32 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
turning the key 3 times is the old school way to pull chrysler codes. didnt think that obd 2 did that anymore
Old 11-23-2013, 01:01 AM
BamaDryver53's Avatar
BamaDryver53 BamaDryver53 is offline
Vehicle: 2000 Dodge Ram 1500 Quad Cab
BamaDryver53 is on a distinguished road
Originally Posted by toddrod View Post
Alright, the check engine light came on again so I tried maddog's method. Unfortunately, I got no readings so i turned the key to off. I dont know how I came up with the idea but I turned the key back to on (without turning the motor) and then off again. I did this three times and the odometer read p0138. Found out I have a faulty o2 sensor. Try what I did if your having problems sourcing a trouble code, it may help.
Tried your idea on my 2000 1500 and it worked. Got a P1740 code? Any idea what that is?
Old 11-23-2013, 08:32 PM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
P1740-TCC O/D Solenoid its located in the transmission oil pan.
