Old 11-19-2011, 12:34 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Default HID's and DRL's
So now that I have found a local supplier of good quality HID kits I'm thinking of finally doing my hi beams as well. Only question I have is how to get around the low voltage signal on the Daytime running lights.
I know the circuit will have to be done with a relay and simply eliminating DRL's will get me a ticket as it's law up here in the frozen north. Couple of questions come to mind.
Being as the DRL is a reduced voltage, will this voltage be enough to open the relay? What is the minimum voltage requirement to open the relay?
Will I get a bulb out or flickering problem?
Thanks in advance.
Big Red my old 2011 Sport
Old 11-19-2011, 12:40 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
I have read if you hook the relay to your high beam wire it will work but have not tried it. looking forward to hearing your progress.
Old 11-20-2011, 06:10 PM
2011 ASSAULT 800's Avatar
Trim Level: Quad Cab Sport
Rep:251
drive around with your lows on and you wont need drls....
Old 11-20-2011, 07:27 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
retro solutions apparently have a solution for low voltrage occurances so check them out....thats where im gonna go to get my new ones and also a set for the jeep
Old 11-26-2011, 06:53 AM
rtkman's Avatar
rtkman rtkman is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:167
rtkman has a spectacular aura aboutrtkman has a spectacular aura about
There are many choices in relays. You can get one that will switch a 600amp service on with a 3.5v battery if you want. Its all about choosing the right one. Measure the voltage on the lows and go from there. surely someone has done it already.
