Spark plug change fail - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-22-2011, 01:15 PM
safetyfast safetyfast is offline
Vehicle: 1996 RAM Laramie SLT 4x4
Trim Level: SLT Laramie
Color: Red/Silver
safetyfast is on a distinguished road
Never mind about the injectors. I see the fuel rail. It's obvious now how to disconnect.
Old 11-24-2011, 09:53 AM
Color: Red/Silver
Finally out. The flats portion of another plug broke off too, despite days of soaking with PB Blaster. After much prayer and switching to CRC Freeze Off spray and a breaker bar, they are free. No damage to threads. Apparently the plugs were just torqued way down in the past.
Old 11-24-2011, 11:35 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Absolutely possible. 5.2 and 5.9. There's supposed to be a small metal square "u" clip in the injector plug but I just changed mine out and they were all missing. Gave 'em a couple'a wiggles and they unplugged no problem.
Old 11-24-2011, 11:40 AM
Vehicle: 95
Rep:1776
Yaaaaaaaaaaaaay
Old 02-11-2012, 04:24 AM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1260
you should be able to unplug each individual injector from the fuel rail. unless its a monorail. If it is then the fuel lines feed the injectors directly. I cant remember for the life of me...honestly. Been 12 years since I looked at a 360.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 02-11-2012, 10:24 AM
Color: Red/Silver
You are correct. That's what I ended up doing. You can unplug each individual injector.
Old 02-11-2012, 11:12 AM
Glad to hear you got them out . For those out there that end up with ruined threads in the cylinder head , I would strongly recommend using a spark plug insert instead of a heli-coil . A insert is a much nicer and permanent repair . A insert can be threadlockered into the head then staked into position with the supplied arbor . Using a helicoil your always at risk of disturbing the helicoil .
