Old 04-17-2013, 03:50 PM
Kcbigbadram's Avatar
Vehicle: 2007 1500
Trim Level: Big horn
Color: Inferno red
Rep:503
Originally Posted by Hardware View Post
Snerk!
Thank God for tow/haul mode and the Jake brake...that might have gotten away from you...
KC, you sure your truck can pull that?
No way in he'll mine could..... Lol
Kidding
I'm just hating cause I'm jealous. Haha
theres no doubt i was way overloaded there
pretty sure the truck laughed at me a few times for even making it pull such a small load
Old 04-17-2013, 05:05 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
I was more worried about your 2500.....I didnt want it to strain anything...LOL
sales@revelperformance.com
Old 04-17-2013, 08:07 PM
2012ramsportellis's Avatar
2012ramsportellis 2012ramsportellis is offline
Vehicle: 2015 dodge powerwagon
Trim Level: power wagon
Color: blue streak pearl coat
Rep:94
2012ramsportellis will become famous soon enough
Did a little offroadin this eve !
Old 04-17-2013, 08:45 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2111
What temp are your HID's? I'm assuming 5000K or 6000K? They look great.
Old 04-17-2013, 11:29 PM
coldfusion73 coldfusion73 is offline
Vehicle: 2016 Ram 1500 CC 4x4
Color: Blue streak
coldfusion73 is on a distinguished road
Nothing fancy...just stock...so far...and yes...we still have snow...getting 10cm tonight also
Old 04-18-2013, 12:17 AM
Hardware's Avatar
Hardware Hardware is offline
Trim Level: Outdoorsman
Color: Black over Grey
Rep:31
You realize the Rams have an exhaust brake, not a jake brake right? There's a big difference.
Oh, really? Please explain...
Compression release engine brake.
...A compression release engine brake, frequently called a Jake brake or Jacobs brake, is an engine braking mechanism installed on some diesel engines. When activated, it opens exhaust valves in the cylinders after the compression cycle, releasing the compressed air trapped in the cylinders, and slowing the vehicle.
Although Jake brake properly refers to the Jacobs brand of engine brakes, the term has become a genericized trademark and is often used to refer to engine brakes or compression release engine brakes in general, especially on large vehicles or heavy equipment.
Old 04-18-2013, 12:41 AM
Revel Performance
Rep:1804
Where are you in Ontario that you still have snow?
We haven't seen snow here in about 3 weeks
satan47's Avatar
satan47 satan47 is offline
Vehicle: 2013 Dodge Ram
Color: Mineral Gray Metallic
satan47 is on a distinguished road
Originally Posted by D33k View Post
love your truck, kinda makes me wish i wouldve waited for the gray or white but i guess silver will do.
Hey there.
where'd you find that all black grill?! it looks sick
LineX,10tint,AriesW2Wsteps,Sonnaxbooster,20x9XDMon sters,295/65/20 TrailGrapplers, 4" CST lift, rear 1.5" spacers/5100's, 87mmTB,SB CAI,18" Maganflow/Y pipe,BT Catchcan, T1000, Factory 4.10s, transgo shift kit and JBA headers, Maghytec diff/tranny cover
Old 04-18-2013, 01:33 AM
Wooj11 Wooj11 is offline
Vehicle: 2013 Ram 1500 CC Bighorn 4x4
Wooj11 is on a distinguished road
What kind of steps are those?
Originally Posted by BigHorn 4 Life View Post
Took some pics today with my new steps on her.
Old 04-18-2013, 02:05 AM
Rep:2111
Yes, as your quote says it is used on heavy duty diesel engines like on semi trucks and such. To put it simply it is like a separate head that opens the exhaust valves to create a vacuum that slows the downward movement of the piston and therefore slow down the RPM of the engine. The are a lot more complex and expensive than an exhaust brake which is what most pick up trucks and diesel RV's run. An exhaust brake is kind of like a throttle body put in the exhaust tube. It has a butterfly that closes to reduce the exhaust flow (essentially creating more restriction) which uses compression to slow down the RPM of the engine. Overall they both have the same idea of slowing down the RPM of the engine but a true jake brake works far better than an exhaust brake ever will. And like I states above, they are far more expensive.
http://www.ehow.com/about_6495304_ex...ake-brake.html
