Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 11-20-2011, 07:14 PM
Ryder2011's Avatar
Ryder2011 Ryder2011 is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Trim Level: se
Color: moca?
Ryder2011 is on a distinguished road
Question she's back together and running,,,but!!
after this drawn out head gasket change,now i have a brake issue,my brake pedal is like pushing on the floor.i pulled the abs fuse and thought that might reset something.the abs light went off and that's it.i pulled the other fuse for the brakes and that light went off but no fix.... any idea what's going on ??? she's been parked for a couple of weeks!!
Old 11-20-2011, 07:43 PM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
Explain a little more on whats happening for example is the peddle extremely soft or it's just not braking. I need a little more clear info to diagnose your problem.
Old 11-20-2011, 08:20 PM
If the pedal is soft, it's usually a mechanical or hydraulic issue, not a program or fuse issue.
What you may have is old fluid, weak lines or a leak. Time to drain, flush, refill and inspect your brake system.
Old 11-20-2011, 10:20 PM
Ryder2011's Avatar
Trim Level: se
Color: moca?
the pedal is hard/tight/it was'nt like that before the gasket change.it breaks a little but not enough to go anywhere safely !
Old 11-21-2011, 01:26 AM
dsdellRam06's Avatar
dsdellRam06 dsdellRam06 is offline
Vehicle: 2006 Ram SLT Quad Cab 4x4
dsdellRam06 is on a distinguished road
definitely sounds like a weak line, and something mechanical. I know on one of my old trucks I hit the brakes went straight to the floor, come to find out that particular push was all an old line needed to go...luckily I was in the driveway. Maddog knows what he's saying and I'm a newbie, but if you're feeling adventurous crawl underneath and inspect those line, especially if you're going to drive...Which I would not recommend
Old 11-21-2011, 01:37 AM
Rep:12
ok if it tight and hard to brake you might wanna check you vacuum line to the Brake Booster. Double check for leaks and proper location on the engine. Also check Brake booster Check valve.
Old 11-21-2011, 10:44 AM
Ryder2011's Avatar
Trim Level: se
Color: moca?
i found that i'm missing a line,1 of 2 i think (rubber hose) out of the booster,i'm thinking that's the problem but i can't locate the hose that came off of it !!
Old 11-21-2011, 02:03 PM
Rep:12
yep that's it. Please Check your Side Left Throttle body ports on the Intake manifold for any missing hose also the hose is usually located behind the Idle control valve on your throttle body .
Old 11-21-2011, 09:09 PM
Ryder2011's Avatar
Trim Level: se
Color: moca?
i've got that one(behind the IACV) ,but there's another male tube connection on the same piece that the large hose is on(on the brake booster) that runs to the throttle body..it looks to be a smaller hose(about the same size as the one that connects to the throttle body above the TPS) but it's not sucking air or can i restrict air by covering it ?
Old 11-21-2011, 11:08 PM
Rep:12
Give me a chance and tomorrow ill hit you up with some pics of the hoses on mine to show you where they all go. It's easier then describing it lol
brakes, head gasket, sensor
