Old 11-21-2011, 06:57 AM
chris0001's Avatar
chris0001 chris0001 is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: SLT QuadCab 4x4
Color: SILVER
chris0001 is on a distinguished road
Default temp. guage
So go out and start the truck this morning, (-9 degrees C). Ten minutes later the frost is gone and I head off to work. Normally the temp. guage slowly raises to just below half over the course of this 20 km trip, however today it did not move atall......I had good heat in the cab. I checked under the hood when I got to work and nothing was leaking, etc. Truck is a 2007 Ram QC 4x4, 90,000km on it. Could this be the thermostat stuck open? Any help would be appreciated. No check engine light, and seemed to run good.
[/SIGPIC]
Old 11-21-2011, 12:16 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
My first course of action would be to replace the thermostat. If it still does this then start checking the temp sensor.
Sure it'll suck, but it'll make you a man
Old 12-17-2011, 11:48 AM
chris0001's Avatar
Color: SILVER
So I replaced the thermostat and things seemed to be good.....Went to work this morning and the same thing happened again, normal,(LOTS), or heat in the cab but the dash temp guage reading nothing. After about 1/2 hr at work started the truck up and the temp guage was reading fine????? This only seems to happen when its cold out? So where is the temp sensor located? I am wondering if the electrical conection could be loose? Any help would be appreciated.
BTW Merry Chrismas all.
Cheers!
[/SIGPIC]
