Old 11-21-2011, 11:09 AM
Ramrob Ramrob is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
Rep:75
Ramrob will become famous soon enough
Default I need help!!! Problem starting after body lift?????
I put a 3" body in my 03' and had zero problems. Adjusted the transfer case linkage a little to keep the 4x4 shifter in the same spot. I just put a 3" in my 99' and it won't start. The truck rolled when it said it was in park so I unhooked the gear shift linkage so I can make sure it is in park. Brakes have lots of pressure and it won't turn over.Transfer case is in 2H and truck is in park. I get nothing. I never had to adjust it in my 03' and even if this one needed it, it's definitely in park now. Is there and safety switches or wires that might be a problem?
Old 11-21-2011, 02:54 PM
Rep:75
Anything would help.
I've checked wires here and there and things look good. Linkage is extended and all back together. Turn the key and nothing, just like as if you were trying to start it in a gear.
Old 11-21-2011, 04:32 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Have you tried starting it in Neutral also?
Sean
Old 11-21-2011, 09:21 PM
Rep:75
Yeah. I've tried everything. I'm going to reconnect anything that had a connector on it just in case something pulled out a little. I don't know what else to do.
Old 11-21-2011, 11:18 PM
Zeus Zeus is offline
Vehicle: 2011 Ram 2500
Color: Rugged Brown
Rep:27
Zeus is on a distinguished road
Neutral safety switch?
Old 11-22-2011, 07:38 AM
snrusnak's Avatar
Rep:1385
That's what I was thinking, but I don't know how that's related to park. If it won't start in either, does that mean it's not related to the N safety switch?
Sean
Old 11-22-2011, 05:16 PM
Color: Rugged Brown
Rep:27
Probably not. I know on the old ones if the NSS went out I think it would just start in any gear. Interesting problem. Def sounds electrical. I dont know what all safeties these trucks have on them. maybe something with the security system? Does the radio and stuff work?
Old 11-22-2011, 10:55 PM
Rep:75
There is no radio in it now. I didn't have the chance to install it yet. It started right before the lift. I gotta get a chance to check all the electrical connector under the hood. At first I thought NSS, as soon as I figure it out I will post it.
Old 11-28-2011, 04:44 PM
Rep:75
nothing yet. Backup lights are not on when I put the gear selector in reverse if that helps anyone come up with something.
Old 11-28-2011, 04:51 PM
Rep:75
I'm thinking a bad ground somewhere. The motor was rebuilt by the previous owner and some stuff isn't routed the factory way. There are 2 ground straps coming from each side of the motor attached to the valve covers that are really tight but still connected. Maybe he put more somewhere else. Gotta fix this soon so I can do more stuff and it needs to go on the road before the snow.
