Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 11-21-2011, 11:19 AM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
Default winter morning startup engine belt slippage
When i start my truck in the winter in the morning, the engine belt slips and makes lots off noise wich a old car should do not a 50 000$ truck,...
i started to do it last winter and now it will mostlikly start to do it again when the temps is gona go down
before the slippage started i could hear a noise coming from the engine bay when cold like if something wasent working proprely like the powersteering or rad fan,..
any off u had this problem
dodge whants me to leave the truck overnight for the second time this winter to fix it, first time they didnt find what was causing this
so if any of u had the same problem i could point them in the right direction
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 11-23-2011, 03:17 PM
AlbertaBound AlbertaBound is offline
Vehicle: 09 RAM
AlbertaBound is on a distinguished road
Hey, I have been getting some squeals and squeaks coming from under the hood since its been below 0 consistently. Its being inspected right now while they take off the leveling kit and fix everything that it damaged.
Does the sound go away for you after the engine is warm?
Old 11-23-2011, 03:48 PM
crusher's Avatar
Rep:363
the sound from the belt does go away when the engine is warm but there is something a pulley im guessing (probably the engine fan clutch or power stering pump)that makes a very quiete noise always when its cold outside
been to the dealer again, they let the truck sit inside for the night and told me the belt didnt slip when start in the morning,...... idiots... i specificly told them that it needed to be cold,... to be outside....
so i have to bring it back so other time
let me know if they find anything on yours
what happened with your levening kit??
Old 11-23-2011, 04:24 PM
Vehicle: 09 RAM
What a bunch of tools. I wish there was some kind of real quality control at dealerships. The leveling kit caused the truck to shudder in 4x4. Although Dodge has released a service bulletin saying "All Dodge rams will shudder and shake in 4x4". From the research I have done it appears dodge couldnt figure out what was wrong with 4x4 so they just said all of them will do it (leveled or not). Mine didnt before so I am removing it. It also blew a ball joint in the upper control arm (a few days later) but that could have been on its last leg. Nice thing is you cant just do the ball joint on this ram it has to be the entire upper control arm (yay!). The Dodge dealership here said they have had a few people blow front difs from the leveling kits after only 5,000-10,000 km. Its mainly the quad cabs that have this issue and not crew cabs. Mopar no longer sells its leveling kit.
Seems like dodge focused too much on the body and interior than the actual parts of the truck. To be honest after reading the thread about driveshafts falling off on new rams Im going to cross my fingers, try to get 10,000km more out of this truck without killing myself and sell it.
Ill let you know what they say about the belt. I have no trust in the dealership here from past experiences so I am getting a mechanics shop to look at it instead. I should be getting it back soon.
Old 11-23-2011, 04:57 PM
crusher's Avatar
Rep:363
okay good luck
for myself ill be wainting a few weeks, when it will cold everyday and ill bring the truck in(well outside,... lol) for the 3rd time
Old 11-24-2011, 03:33 PM
my hemi my hemi is offline
Vehicle: 2013 ram sport regular cab
Trim Level: sport
my hemi is on a distinguished road
Thumbs down
when i star my truck in the morning since it been cold its sound like a valve is clicking and then it stop 3500km
Old 11-24-2011, 03:39 PM
Rep:4072
Sounds odd for such a new truck but at times when it actually does get cold here, I will get a pulley squeak as well. Chances are, if it goes away when the engine warms up and doesn't do it in warm weather, the grease that is inside the pulley bearings is just cold and needs to work itself around but once it does the noise should stop, it does for me anyway. I would be concerned, though, if your belt is actually slipping.
