Old 11-21-2011, 05:24 PM
jakeryii's Avatar
jakeryii jakeryii is offline
Vehicle: 1985 ram charger d350
Trim Level: custom towing packag
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
jakeryii is on a distinguished road
Default slammed D350
ok ok ill begetting my license here soon and my dad will be giving me his old 86 dodge ram D350 it has 70k on the clock as far as the drive train goes its a la series 5.9 liter 360 v8, 4 speed granny gear manual trans and i think Dana 44 in the rear (plz correct me if im wrong) it was custom ordered from the factory to be put to use on a a farm by the original owner (why it only has 70k) and we are only the second owner the badging says d350 custom so im not going to worry out keeping stock or original so my plans are to lower it by cutting 2 coils out of the front springs and flipping the rear leaf spring mounts, the ditch the old bed its rusted out in the middle were a steel plate has be put in through a hole cut in the bed and bolted to the frame ill be keeping the steel plate in there be cause im going for a hot rod/ utilitarian look so ill be doing a flat wood bed ill post some pics up that i found in a few
Old 11-21-2011, 05:30 PM
jakeryii's Avatar
pic of the beast
Image11212011132757 by jakeryii, on Flickr
http://www.************************/...=D250+lowering is were i got my info on lowering the rear
and the front
http://ramchargercentral.com/technic...g1867/#msg1867
more pics
inspiration
inspiration by jakeryii, on Flickr
photochopped
lowered and chopped by jakeryii, on Flickr
Old 04-02-2012, 05:30 PM
jakeryii's Avatar
well i popped out the dents and lost my job before i could get it torn apart so it looks like it may be a 2x4 sand rail down in the obx
Old 04-06-2012, 10:25 AM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Keep us updated.....
