Old 01-30-2012, 09:46 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The proper thing to do would be pull the valve covers, check each valve stem to rocker arm clearance with a feeler gauge, and adjust them all (if needed) to the appropriate clearance (by shimming the lash adjusters). I'm not sure what the appropriate clearance is, but I'm sure it can be found. Again, member superiorstyles has a lot of information regarding this.
EDIT: The reason I say check/adjust them all is because he said before that he did not initially check/adjust any of them. It is something that should be done and since he didn't do it then it should be done now. Some may not need adjusting but they need checked to be sure.
Sean
Old 01-30-2012, 10:22 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Lol, I understand your point but the proper clearence is 0 lash. No offense but i t doesn't take a rocket scientist or a feeler gauge to find 0 lash, lol. The easiest way would be to leave the covers on and find the culprit with a makeshift stethoscope while the engine is running. He can search for his vacumm leak at the same time. If all else fails then he can go back and inspect them all. He can use the feeler gauge when he finds the culprit.
Old 01-30-2012, 10:42 AM
snrusnak's Avatar
Rep:1385
Zero valve lash is not correct, especially with hydraulic valve trains. Normally if you adjust the lash this way you get valves that don't fully close. It's possible to get close to the appropriate clearance without a feeler gauge, you can adjust it until the push rod(or in this case valve lash adjuster) is just barely able to wiggle by hand(and I really mean just barely), but why would you do this when you can do it the right way and have accurate lash set with a $0.99 feeler gauge, not to mention it doesn't take any more time. There's nothing wrong with identifying which one is tapping, but personally I would want all the valves to have the proper clearance. I don't think chrysler checks and adjusts this from the factory, as about every engine has the same noise. I believe they feel that the hydraulic adjusters will make up for the loose clearance, which they do, eventually. He could probably leave them and it'd be fine, but it seems like he wants to get it perfect, so the best thing to do is to get proper lash on every valve. There's no point in doing one or a couple when the others may be out as well. There may not even be a published lash from chrysler, but typically for a hydraulic valve train you want about 0.030", adjusted using the correct method, I assume the valve lash adjusters are basically the same design as a lifter...Many people make mistakes when adjusting hydraulic lifters because they bleed down.
Sean
Old 01-30-2012, 11:45 AM
RadioFlyer's Avatar
Rep:146
Zero valve lash is not correct, especially[CODE][/CODE] with hydraulic valve trains. Normally if you adjust the lash this way you get valves that don't fully close. There may not even be a published lash from chrysler, but typically for a hydraulic valve train you want about 0.030", adjusted using the correct method, I assume the valve lash adjusters are basically the same design as a lifter...Many people make mistakes when adjusting hydraulic lifters because they bleed down.
Lol...no pun intended, but it's evident that you don't have any experience adjusting valves. Hydraulic cams call for 0 lash and 0 clearence...not .030 so to save arguement I think it's best for me to but out of this topic...good luck IN2H20.
Old 01-30-2012, 11:59 AM
snrusnak's Avatar
Rep:1385
0.030" of lifter preload. Most hydraulic lifters have about 0.060" of plunger movement, and you want it preloaded to about half of that, so 0.030". If you have the preload too loose or too tight the valves will either not fully close or the rockers will be loose causing tapping. I'm not positive if the OHC lash adjusters have the same range of movement, that's why I said it would be best to find a publishing from chrysler, or test the range of the plunger before install, or some other method to figure out the range. While on the engine you should be able to use a feeler gauge to find the range and then you can get the middle point. My whole point is that it should not be done by guessing, it'd run but not as good as it should and it could cause premature lifter failure.
EDIT: IN2H2O, I think superiorstyles would have an answer for you, and he always seems happy to help out. I'm applying what I know of lifters to the lash adjusters assuming they operate the same, but he has actually built these engines so has more experience than I do. He is the one who told me how you make the adjustments by shimming and not by adjusting the rocker arm (that was news to me).
Sean
Old 01-30-2012, 04:00 PM
RadioFlyer's Avatar
Rep:146
First of all you are contradicting yourself, lol. You said that my 0 valve lash adjustment was wrong and the correct lash was .030, you never mentioned anything about preload. Second, preload has nothing to do with valve lash in this case. Preload is the distance that the pushrod submerges into the lifter. It has nothing to do with the distance the plunger travels in the lifter. Third, adding shims to the bottom of the adjuster is to help correct the geometry that may have been altered by switching what ever valvetrain parts from one engine to another (if he did). Lol, and last...I am happy to help as well but I can't say that about you constantly insulting my inteligence when ever I chime in to do so. I hope this freind of yours schools you somewhat about lash and preload when he chimes in because the info you got from the internet doesn't apply in this case and I'll let him tell you why, lol.
Old 01-30-2012, 04:29 PM
snrusnak's Avatar
Rep:1385
Hey RF I'm not trying to insult your intelligence. It seems like any thread we post in together this happens; some people just can't get along huh?
I have never done this on the 4.7L, but I believe it to be the same application as "normal" hydraulic lifters. Wouldn't you agree that the proper amount of lifter preload is important, rather than just guessing at it by putting shims under a noisy lifter? If you do just guess at it then you don't know how much to shim it, unless you check the clearance at the valve. Zero lash should only be achieved once the lifters are filled with oil; when they are not filled with oil the lash should not be adjusted to zero or the valves will not close all the way once they do fill with oil. This is the way I understand it, and how I've applied it in the engine's I've put together(I learned the first time I put an engine together that the lash should not be zero because when you try to fire up the engine and the valves aren't closing you don't get compression and it doesn't start...I then figured out after days of head scratching and with help from a friend that I had adjusted them wrong).
Sean
Old 01-30-2012, 04:47 PM
Rep:2620
It all goes out the window IF you have a collapsed lifter
which is not too unusual in high mileage engines
Old 01-30-2012, 08:24 PM
RadioFlyer's Avatar
Rep:146
Very true...here's a little something of interest. Not the same problem but similar so "listen well you must" young Skywalker (snrusnak), lol!
Old 01-30-2012, 09:56 PM
snrusnak's Avatar
Rep:1385
GT, he had said that he changed all the lifters to try and fix the problem, and no doubt it is possible to get faulty new parts, but it seems unlikely.
RF, you speak for yourself. What you posted is video of the text that I posted: too loose of a lash (and preload) will allow the tapping and in his case in the video, the rocker to pop off when the lifter bleeds down. His fix was to measure and find the range of the plunger in the lifter, then used a shim to adjust the preload to about half of the range, which is about the right preload. Notice he also checked compression on the cylinder to ensure that preload was not too much (valves not closing all the way). And it does actually appear to be the same problem.
This is exactly what I think should be done in IN2H2O's case, but I think he should check them all, to be sure they are all ok.
Sean
