Old 11-21-2011, 10:16 PM
californiajed californiajed is offline
Vehicle: 2011 Dodge Ram
Trim Level: Crew Cab
californiajed is on a distinguished road
Default Bilstein 5100s on RWD?
Can anyone confirm whether the ride height adjustable 5100s can be installed on a 4th generation CC Ram with RWD? Just looking to level the front. The Bilstein web site was ambiguous as to whether this can be done.
Thanks!
Old 11-21-2011, 10:46 PM
CaddyRam's Avatar
CaddyRam CaddyRam is offline
Vehicle: 2010 Ram
Trim Level: Slt Big Horn CC
Rep:12
CaddyRam is on a distinguished road
I think they replace the strut and are for 4wd only. Someone will confirm or deny soon I am sure.
Mufflex18,limo tint,DNX 6960w/rearview camera, sirrius satellite,DVD,Nav,radar detector/video camera mount, Damplifier.Ez down tailgate assist,bed extender, LineX,relocated rearwindow switch,custom twin filter air intake,custom front/rear center consoles w10'' Kappa and LED lighting.
Old 11-21-2011, 10:58 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I don't think you can use the adjustables. Go to bilstiens website
And it will tell you what shocks are available for your truck. I'd do it for you but it's a pain on my phone
Old 11-21-2011, 11:06 PM
That's what I did, and why I posted the question. I can't tell from the search results (below) what the answer is...
Setting: Show All Settings
4600 SeriesBilstein 4600 Series Shock Absorbers and Struts are designed specifically to help your truck, van or SUV reach its pinnacle in ride performance and handling, while still providing the comfortable ride that has come to be expected from the name BILSTEIN. A 4600 Series equipped vehicle offers superior control compared to conventional alternatives, allowing you to keep cargo secure-from your kids to work equipment, mile after mile. Utilizing our patented design, the dampers allow the vehicle to glide over every type of road surface you may encounter while maintaining complete command at all times. These dampers are the least expensive and most effective upgrade to extend the service life of any vehicle out on the road today.
5100 SeriesBilstein 5100 Series Shock Absorbers are high gas pressure monotube shocks designed specifically for lifted pickups, SUVs and Jeeps. The shocks feature a 46mm digressive piston with self-adjusting deflective disc valving. They offer super damping ability that makes them ideal for heavy hauling or occasional off-road use, while maintaining an exceptional street ride. (zinc-plated steel body, Triple-C-Technology® coating )
5100 Series (Ride Height Adjustable)Bilstein 5100 Series Ride Height Adjustable Shock Absorbers are designed for front coilover style pickup suspensions. The monotube shocks feature a 46mm digressive piston with self-adjusting deflective disc valving. Multiple snap-ring grooves in the shock body allow for different spring seat positions, providing 0"-2.5" of front end lift, depending on application. Provides increased wheel travel and improved handling! (zinc-plated steel body, Triple-C-Technology® coating )
46mm Monotube Shock Absorber (click for more info)
Part Number: 24-187510
Setting: 4600 Series
Drive Type: RWD
Position: Rear
Old Part Number: F4-BE5-G779-H0
Part Number: 24-187480
Drive Type: RWD
Position: Front
Old Part Number: F4-BE5-G740-H0
Old 11-22-2011, 11:07 AM
Color: Mineral Gray
Rep:177
Not sure why but sometimes there site will have them in the list even though they ate unavailable and when you click on the nothing shows up. It drives me nuts
Old 11-22-2011, 01:33 PM
Me too! I called and confirmed there's no application for RWD. Guess I am stuck with spacers.
