Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 11-21-2011, 11:25 PM
10Laramie 10Laramie is offline
Vehicle: 2010 Dodge Ram Laramie
Color: Mineral Gray
10Laramie is on a distinguished road
Default Squeak, squeak.....HELP!!!!!
Hello all,
My truck (2010 w/ 31k miles) has developed a bad squeak on gravel roads and I need help with diagnosis. I thought it was caused by my recent HBS leveling kit install but I decided to remove the kit and the noise is still there. I did not notice it before the install but had noticed a similar noise a few months back that went away on its own.
The noise doesn't seem to be coming from the front end, strangely enough given the circumstances. My first thought was the tailgate but I sprayed WD-40 on it and it didn't help.
Any advice or help would be greatly appreciated.
Thanks.
Old 11-22-2011, 08:55 AM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
Check your sway bar links. You can hit them With penetrating oil the squeak will fade a bit or go away completely. This will not fix them permanently only temporarily. There are some on the front and rear Axles
Silence! Differing opinions will not tolerated
