Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 11-22-2011, 07:41 PM
Dodger98's Avatar
Dodger98 Dodger98 is offline
Vehicle: 1998 Dodge Ram 1500 4x4 (5.2L)
Rep:12
Dodger98 is on a distinguished road
Default 5.2 with no "gitty up"
I dont know if its just me or not, i dont have another truck to compare it too but my 98 ram with the 5.2 has no "gitty up"
it has a hemifever custom tune, aem brute force intake, new plugs (autolites) wires are good, 4.56 gears and a stall converter, shift kit
for all these mods i would expect more, but i got 285/70r17 tires and it just dont seem to have the kick it use too
now i use to run 285/75r16 tires, but then i went to bigger tires, but i also swapped out 3.55 for 4.56 gears
i have a ton of torque, but 0-60 is....well there is more to be desired.
I got all the mods done, i wonder if i got something plugged...and yes i use seafoam via tank and vacuum line
Old 11-22-2011, 07:46 PM
hmmm....the 5.2 has never been known for great performance until they get built, stroked and some better breathing heads put on. You only have so much to work with here if the basic engine is still stock.
Old 11-22-2011, 08:00 PM
Dodger98's Avatar
Rep:12
yea the motor itself is bone stock. I have the programmer and cold air intake, thats all for the motor part, I always use the best stuff (plugs, wires etc.) on my truck
Its prolly been asked millions of time, but is there a way to build up a 318 to be decent. Every time i ask this, im always told to swap for a 360. Why do that when my 318 runs fine. I know i can get more power from a 360, but a 318 shouldnt be far behind.
What can i do to improve performance. Its my toy, driven only about 500 miles a year, so mpg is not a problem.
what can 1k buy, or 1,500 buy?
or should i just try a high flow cat. The cat i have is prolly clogged with junk
Old 11-24-2011, 12:21 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
a high flow cat might help but with the gearing its not going to be a speed demond at all it should take off like a bat out of hell but loose on top and mid line. and being that its a stock block and head set up that wont help ether. you might need bully dog programer tb mod (better throttle responce and free) compucam. those are a thought
Old 11-24-2011, 12:33 AM
ramfam's Avatar
Trim Level: Base
Rep:21
oh my bad you have a progamer sorry bout that
Old 11-24-2011, 11:24 AM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
On a '96 I would check the cat before buying a bunch of mods... those old style cats are known for plugging.
If it happens to be the cat, I would have your exhaust folks mod the y pipe with a magnaflow y to remove any restrictions then run a high flo converter.
I've read on other formus that the results are impressive!
Old 11-25-2011, 11:24 AM
Dodger98's Avatar
Rep:12
Default cat
anybody got a link to the magnaflow high flow cat for good price
i found magnaflow cats online, but none say they are high flow
where do you get one for a good price?
Old 11-25-2011, 06:22 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I agree. Otherwise it just seems like you're putting lipstick on a pig and calling her your date. I changed to a high flow cat and being a bone stock 5 spd I have to ballast the rear in the rain.
Old 11-25-2011, 08:42 PM
ramfam's Avatar
Trim Level: Base
Rep:21
any after market will work better then stock. there is one at auto zone that ive had my eye on it fits stock and has two seperate pipes in and one out insted of the y being welded together.
Old 11-25-2011, 08:43 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Take that thousand bucks, get the Hughes RPM AirGap mpi intake and get a better cam. At least do the intake manifold. If you don't want to go into the engine, add 1.7 rocker arms with better valve springs. A high flow cat is useful and will compliment top side improvements.
