Old 11-23-2011, 01:57 PM
Tpellus Tpellus is offline
Vehicle: 2003 Dodge Ram 1500
Color: Dark Pearl Red
Tpellus is on a distinguished road
Default 2003 1500 LED Conversion
Who here has a 2003 that has changed factory lights to LED's. I have searched through the forums and have no found anything with my year. I have seen other 3rd Gen trucks with them but am not sure if the lighting is all the same throughout or what. Just wanting some information on what I need to get. This whole LED thing is confusing me!
Old 11-23-2011, 02:15 PM
Google up Sylvania Osram bulb guide, then check that for your interior bulb numbers. Then, at SuperBrightLEDs.com or autolumination.com, you can find a crossover to that bulb in an LED version.
One thing to remember, they don't all come in the same length so it's a good idea to measure the overall length of your stock bulbs (the specs might be on the Sylvania site...) then check that against the LED specs.
You can find info on interior and exterior bulbs. If you want to put in LED's for the turn signals, you'll need some resistors to avoid hyperflash and the potential for the bulbs to stop working. autolumination has some great resistors already cased, wired and ready to go.
Old 11-23-2011, 02:36 PM
Awesome, I checked it out and started to make a little more sense. Thanks
Old 11-24-2011, 07:15 PM
2011 ASSAULT 800's Avatar
Trim Level: Quad Cab Sport
Rep:251
if you have an owners manual all of the bulbs are in there, it has every single bulb the truck has on it that will give you what number each bulb is then go to a LED website or somewhere else and choose what you want there should be a sticky thread at the top of the lighting category and in it should be mst of the led's for 4th and down the page a bit should be 3rd gens
