Old 11-23-2011, 08:32 PM
rob1218 rob1218 is offline
Vehicle: 2004 Dodge Ram
rob1218 is on a distinguished road
Default Ignition Run Only fuse keeps blowing
Hi I have an 04 Dodge Ram and and the "Ignition- Run Only" fuse keeps blowing everytime i turn the ignition on... It is the pink 30 amp fuse..
Does anyone know what this fuse does?? The truck still seems to start fine..
I did notice the AC controls seem non responsive.. not sure if this is related but i think it is..
Any help with this problem or suggestions would be GREATLY appreciated. Thanks for your time and help.
Old 11-23-2011, 10:31 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Is this Fuse #3?
In the IPM (Fuse Box) It will be the 3rd 30A fuse. Fuse 4 is 40A.
Do you have the rear window defrost option?
brad
Interested in one of my mods?
Old 11-23-2011, 10:52 PM
Yes it is the 3rd fuse... 30 amp
And no it does not have rear window defrost..
It doesn't have power door locks or windows either..
Does anyone know if its safe to drive the truck with this fuse blown?
Old 11-23-2011, 11:21 PM
brad12kx's Avatar
Rep:2581
At this stage, I will say that it is NOT safe to drive the truck. I'm currently looking over the circuit, and Fuse 3 powers alot of important stuff. Give me a couple of minutes and I will give you some troubleshooting ideas to isolate where the issue is.
brad
Old 11-23-2011, 11:26 PM
Thanks so much!! I really appreciate the help. If I can get this resolved I would like to make a donation to you and the forum.
Old 11-23-2011, 11:27 PM
brad12kx's Avatar
Rep:2581
I'm hoping you have a few spare 30A fuses...LOL
This procedure is going to be trial and error.
Can you pull the following 'Second Stage' fuses and see if Fuse #3 still blows.
Fuse 36 (10A)
Fuse 37 (??A)
Fuse 38 (15A)
Fuse 35 (10A)
Fuse 52 (20A)
brad
Old 11-23-2011, 11:30 PM
Yeah these fuses are expensive too!!
I figured this would be the case.. just to let you know im not sure if this is normal but the other side of the fuse (non battery side) shows ground once i turn the ignition on..
I pulled all the relays and it still shows ground.. not sure if this info helps at all but thought i would let you know..
Going to pull all those right now and let you know. Thanks
Old 11-23-2011, 11:34 PM
brad12kx's Avatar
Rep:2581
The 'ground' reading is expected. A 30A fuse can drive a load of .3 ohms, so unless you have a real sensitive ohm meter, it will look like ground.
brad
Old 11-23-2011, 11:35 PM
oh ok thanks for the clarifcation..
#38 is an airbag fuse.. is this safe to pull?? it has the yellow holder on it..
Old 11-23-2011, 11:37 PM
Sorry i meant fuse 52 not 38
