Old 11-24-2011, 12:10 AM
rob1218 rob1218 is offline
Vehicle: 2004 Dodge Ram
rob1218 is on a distinguished road
okay i think i found it.. it is right below the steering column on the left side..
Here is a pic i took of it.. all of the ignition wires go to it.. the other side of the wires go toward the firewall and combine into another huge harness..
pic is huge sorry..
you can see it here.
http://www.precisedevelopment.net/ignitionharness.jpg
Old 11-24-2011, 12:12 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
You the Man!!
That's it (I'm 99.994% positive).
Unplug that puppy and test for ground at the fuse.
brad
Interested in one of my mods?
Old 11-24-2011, 12:19 AM
You the Man!!
ok here is the tricky part.. I didnt think about it..
But it was only showing ground when the ignition was turned on.. and showing nothing when the key is off.. and now that that harness is unplugged.. when i turn the key to "ignition".... the key is essentially doing nothing..
So it did not show ground this time. lol
Old 11-24-2011, 12:23 AM
brad12kx's Avatar
Rep:2581
Good thought....I forgot about that, but with it disconnected, we can now test right from the plug.
In you pic, the 2 wires at one end are Red and Pink/Yellow (the opposite end should have very heavy Red and a thin Black)
The wires on this end (Red and Pink/Yel) are the ones we are interested in. The red is from the fuse, and the pink/yel is the feed to the fuses we pulled. Check both. Both 'should' check open, but I'm willing to bet the Pink/Yel looks like a ground.
brad
Old 11-24-2011, 12:25 AM
brad12kx's Avatar
Rep:2581
Oh Boy....another typo!
I bet you looked at the connector and said.....The other side has a Heavy Red and a Heavy Dark Blue.....
brad
Old 11-24-2011, 12:31 AM
Yes sir you are absolutely correct.. Pink/Yellow is showing ground.. Red is showing open..
Old 11-24-2011, 12:32 AM
brad12kx's Avatar
Rep:2581
Well, at least we know the ignition switch is NOT the problem.
Next test -
BTW - Do you have the battery disconnected?
brad
Old 11-24-2011, 12:34 AM
Next test -
No I don't.. should i disconnect it??
Old 11-24-2011, 12:36 AM
brad12kx's Avatar
Rep:2581
Not yet. I like the having power as a reference.
Next test is at Fuse 37 (the spare). What I want to know is if the 'ground' condition shows up on the power side of it. In a perfect world, it will show open on both sides.
brad
Old 11-24-2011, 12:43 AM
37 is showing open on the Battery side.. and showing "ground" on the other side.. hmm..
