Ignition Run Only fuse keeps blowing - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 11-24-2011, 01:47 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
That is completely unexpected.
I wonder if it is wired backward inside the IPM, and the side that we think is batt, is actually the circuit side....Hmmm.
Try the same test at fuses 35, 36 and 38. I wonder if there is some strange connection that we need to know about.
brad
Interested in one of my mods?
Old 11-24-2011, 01:52 AM
rob1218 rob1218 is offline
Vehicle: 2004 Dodge Ram
rob1218 is on a distinguished road
All of them are showing open on "battery side" and ground on the other side except for 36.. that one is showing ground on both sides..
i test another one of the fuses down that same row.. #19.. with fuse in is shows powers on both sides.. fuse out is shows power on the "battery side" and open on the other.
Old 11-24-2011, 01:57 AM
brad12kx's Avatar
Rep:2581
Well that leaves us wondering....
Just to verify that we are not going in the wrong direction, can you -
a) Disconnect the battery
b) check for continuity between the Pink/Yel at the ignition switch and Fuse 37. Also check the continuity between that very circuit and ground. I'm of the feeling the IPM has some strange wiring, so want to make 100% sure we don't chase ourselves in circles. LOL
brad
Old 11-24-2011, 02:01 AM
okay i'll try that.. might be tricky not sure if my dmm leads are long enough.. gonna have to do some quick extends.
Old 11-24-2011, 02:04 AM
brad12kx's Avatar
Rep:2581
The other option is to pull the IPM....which we'll will likely do anyway.
Have you ever remove it before?
brad
Old 11-24-2011, 02:08 AM
Yeah i think i have.. should i pop it out?
Old 11-24-2011, 02:11 AM
brad12kx's Avatar
Rep:2581
You bet.
Here is the quick blow by blow -
First thing - disconnect the battery.....both leads.
Then remove the battery cable and accessory cable from the IPM
(engine side).
Then remove the 2 mounting screws/bolts.
The first is located on the front of the IPM, engine side. It is a vertical
screw. I believe it is a 10mm socket or T25 torx.
The second is on the front fender side. This is a bolt (horizontal) to
the fender.
Then pull the IPM toward the engine and lift up.
brad
Old 11-24-2011, 02:26 AM
You bet.
(engine side).
the fender.
Sweet! it is out... aside from the plugs on the bottom..
brad12kx's Avatar
Rep:2581
The connector of interest on the bottom is C5. I believe it is green.
Here is a diagram of the underside -
Depress the locking tab and rotating the connector arm outboard to release the connector.
Once C5 is disconnected, check for 'ground' on the Pink/Yel at the steering column.
brad
Old 11-24-2011, 02:28 AM
okay.. i disconnected both positive and negative terminals on the battery.. should i hook it back up before i test for ground?
