Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 11-23-2011, 10:23 PM
Gp1200r2000's Avatar
Gp1200r2000 Gp1200r2000 is offline
Vehicle: 2014 Ram 1500 SLT CREW 4x4
Trim Level: Big Horn SLT
Rep:35
Gp1200r2000 is on a distinguished road
Default Help with front end shake please
Guy has the truck 2.5 front and leveling kit and then took it to get alinement with the factory 20 inch rims and factory size tires,truck rode awesome going to the shop,after the alinement,4 days later my new 20 inch rims and factory size new tires where added and it now seems like i get a shake around 60-80 mph sometime it worse then others and sometimes it not bad or nothing at all,Any help would be great full..Thanks again and happy turkey day guys.
Old 11-23-2011, 11:23 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
the centerbore on your aftermarket rims is greater than the stock centerbore. you need hubcentric rings.
Too many mods to fit here!
Old 11-23-2011, 11:25 PM
Rep:35
Default I have it
Yes thay came with my rims,Im wondering if i should try taking them off .
Old 11-24-2011, 12:41 AM
Aftermarket rims? If so, you may need some hubcentric rings.
Did you recently change out to a different tire?
Old 11-24-2011, 03:43 AM
AlbertaBound AlbertaBound is offline
Vehicle: 09 RAM
AlbertaBound is on a distinguished road
Due to a design issue with Dodge Ram front differential and suspension, some owners may experience a vibration in the front end when in 4x4 mode, or a violent shaking vibration of the front wheels when going over a bump at speed. These two symptoms are often called a "death wobble", but actually appear to be two different problems with the Ram truck.
The 4HI mode vibration is a vibration or shudder that occurs when accelerating in 4x4 high mode. This affects Dodge Ram 1500 non mega cabs; Dodge couldn't discover why their stock trucks would do this for some customers. The solution for Dodge was to state that there is no problem and that all of the new Rams will shudder or shake when in 4x4 high. This symptom appears isolated to 2006-2011 1500 non-Mega Cab model trucks and when in 4-hi mode.
It is ReadyLift Suspension's position that if you have installed a lift kit onto your Dodge Ram truck and experience either of the two symptoms mentioned, you have two options. 1). IMMEDIATELY HAVE THE LEVELING KIT REMOVED FROM THE VEHICLE! or 2). Install KORE High Angle CV Joints which will fix the factory issue.
Leveling kits and new Rams dont get along too well. I had to remove mine because of the 4x4 wobble. Its out nice and drives perfectly again.
