Alignment specs for 2011 express - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-24-2011, 11:12 AM
LeroyJaxson's Avatar
LeroyJaxson LeroyJaxson is offline
Vehicle: 2011 Ram 1500
Trim Level: Express 4x2
Color: mineral grey
LeroyJaxson is on a distinguished road
Question Alignment specs for 2011 express
I have a 2011 express with 4000 miles and i am seeing some bad wear in the outside of both front tires. If you look at it from the front the tires look like the are pointing out at the top (positive camber) I made an appointment to have it looked at and i was advised it would probably not be covered under warranty. Before I get the run around does anyone have the alignment specs for my truck? Any help with this will be greatly appreciated.
Old 12-29-2011, 02:26 PM
bluedodgeram's Avatar
bluedodgeram bluedodgeram is offline
Vehicle: 2011 Ram Sport 4X4 Crew Cab
Color: Deep water blue pearl
Rep:13
bluedodgeram is on a distinguished road
Before 20,000 Kms. The alignment suppose to be covered under warranty. Any wear item like brake pads, clutches (manual transmission), wiper blades, etc... Don't let them gouge you for repair work. You'll find it in the maintenance book. Bring that as proof, it's written in black and white. Hope this helps you.
