Old 11-25-2011, 03:33 AM
kiddynamite's Avatar
kiddynamite kiddynamite is offline
Vehicle: 2010 Ram 1500 4x4
Trim Level: Sport Crew Cab
Rep:35
kiddynamite is on a distinguished road
Default Rear Drop
I am thinking about lowering the rear of the truck 2" with the Ground Force coil/shock kit (#91214) and was wondering if anyone has any experience or info on this? Will ride quality suffer at all with such a small drop? I had a slammed s10 back in the day and the ride sucked...but i dropped it way more than 2 inches.
Also, this might be a dumb question, but the "death wobble" only occurs when lifting the front end of the truck right?
Thanks.
Old 11-25-2011, 03:47 AM
BigH0ss's Avatar
BigH0ss BigH0ss is offline
Vehicle: 2013 Ram
Trim Level: Regular Cab 4x4
Color: Maximum Steel
Rep:122
Ask dodgert he has it on his. He said it made the ride better over stock. Ur not going to get dw w a drop. I'd say go for it! I went w ground force for my drop and I like it.
Old 11-25-2011, 09:30 AM
WarBaby's Avatar
WarBaby WarBaby is offline
Vehicle: 2014 5.7 Ram 1500 RCSB/2WD
Rep:43
WarBaby is on a distinguished road
Thumbs up
Thanks.
I have the GF 2" rear drop on my `11 and am happy--no issues at all. The ride seems about the same and it looks much better, IMO. Go for it!
If it's not broken, fix it till it is!
Old 12-01-2011, 12:50 PM
25bduse 25bduse is offline
Vehicle: 2011 Dodge Ram Quad Hemi
Color: Rugged Brown
25bduse is on a distinguished road
I am thinking about doing the same drop and need advice also. How much will it effect towing? Will it sit completely level? I read something about 1/4" spacer on another thread.
Old 12-01-2011, 01:19 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I believe the way they design them is to have the same payload, so towing shouldn't be effected, but may sit a little lower in the rear is all. I cut an extra set of RT springs to lower mine, and have my stock springs as well (they have about 25% more payload to start out with). If I ever tow/haul a heavy load I'll swap out the springs as it's extremely easy and only takes about 30 minutes start to finish.
Sean
