Old 11-26-2011, 08:17 AM
jomikedi jomikedi is offline
Vehicle: 2011 Dodge Ram
jomikedi is on a distinguished road
Default Mopar Fog Lights connector question
I purchased the Mopar Fog Lights for my 2011 Dodge RAM SLT. These are the lights that fit up behind the license plate (not the round lights). The install was no problem until I got to the TPIM box. The instructions say to connect my white wires to the Green C3 connector in ports 23,24. Well there is already a wire in one of those ports. I removed that wire and plugged in my wires anyway but the fog lights would not come on. I found in some forum threads that some people said the instructions were wrong and to use the gray connector, some of the people said to use ports 11,12 (there was a black wire in port 11) of this connector and some said to use ports 11,16 (there was black wires in 11 and 16). Well I tried all of these combinations (removing the black wires) and none of them made my lights function. My questions are.....
Do I have to have my truck flashed before these lights will work (I don't care about the dashboard indicator)?
Which ports should I use (green connector 23,24 or gray connector 11,12/11,16)?
Old 11-26-2011, 10:45 AM
Yes, you also need a flash for them to work.
