Old 11-26-2011, 02:07 PM
oldpokey's Avatar
oldpokey oldpokey is offline
Vehicle: 2000 dode ram 1500
Color: green
oldpokey is on a distinguished road
Default running rough
my trucks been acting up latley at a idle it runs super rough and about stalls out, if i shut it off and restart itll clear up for a little wile then go right back to it, it had a check engine light on i read the codes, there were for o2 senors. i went ahead and replaced both. no check engine light still running rough, truck has 2000 model 140,000 miles 5.9 v8. any pointers??
Old 11-26-2011, 02:50 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:74
Intake belly pan gasket. take a flashlight, open the throttle body blades so you can see past them to the bottom of the intake manifold. Is it oily looking? If so, it's bad.
Old 11-26-2011, 04:55 PM
oldpokey's Avatar
Color: green
it ended up being the idle air control valve, i have one more problem with it. i have a roaring noise when i let of the gas and coast and when i go around a curve to the right it gets awfull loud and i can feel it in the floor board. i can keep my foot on the gas just a little bit and the noise goes away as does the feel in the floor board..i just had the tranny rebulit and i checked all my wheel bearings... im thinkin its the rearend but not sure how to go about making sure if it, any help would be awesome.
runs bad, sensor, stall
