Old 11-26-2011, 09:24 PM
95ramsport 95ramsport is offline
Vehicle: 1995 dodge ram 4x4 sport 5.2
Trim Level: Sly larimine
95ramsport is on a distinguished road
Default No low end power just too end
I have put new heads on my truck and my truck does not have hardly any power on the bottom end it won't even power brake but seems to have decent power on the top end what could be causing this please help and the truck runs great besides this
Old 11-26-2011, 11:33 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Need details. Why replace the heads? Stock or aftermarket? Is this different from how it ran before the swap?
Old 11-27-2011, 08:11 AM
Ok I was doing the Hughes plenum fiX and then I took my heads off cause there were a couple of broken bolts Were my exhaust manifold bolts up so while I had the heads off took them to the machine shoo and he showed me were they were cracked and so I bought some redone stock heads and the truck has a little more power than it did before I took it apart but has a real slow excelleration I mean you have to really press the pedal to go some were
Old 11-27-2011, 12:54 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
timeing set? cam may be worn. or theres a vaccum leak.
Old 11-27-2011, 03:29 PM
Rep:85
Makes me wonder about vacuum since you would have to fiddle with the EGR port. 1995, right?
Old 11-28-2011, 09:06 AM
I didn't Change the cam or timing chain and I block off my egr
Old 11-28-2011, 01:19 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Have you checked compression in engine? The new heads might have brought something else out.
Old 11-28-2011, 07:33 PM
Rep:85
Just trying to get a better picture here. How, exactly, did you block the EGR?
Old 11-28-2011, 08:36 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
bottom line every 5.2 ram ive driven and the one im driving now didnt have alot of bottom end exceleration. everything ive done to my truck has helped a little bottom end but the most top end.
plus your truck might have a limited slip rear end. i can barelly get mine to power break either. but mines a 98 not equiped with egr.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
