Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
United Radio
Old 11-27-2011, 09:59 AM
WolverineMarine's Avatar
WolverineMarine WolverineMarine is offline
Vehicle: 2008 Ram 2500 4x4
WolverineMarine is on a distinguished road
Default Tire pressure question
What is the best tire pressure to run my stock michellin tires at without triggering the sensor light..The sticker on the door in the truck says 45psi for the rears and 65 for the fronts..I'm not doing any towing..just daily driving..any suggestions?
Old 12-04-2011, 02:05 PM
moparornocar72's Avatar
Rep:630
unfortunately I believe the lowest u can go without triggering the light coming on is 4-5 below the recommended specs. But if you can live with the light then u could run them lower.
14.268 @ 95 MPH Full Trim
Old 12-04-2011, 02:29 PM
Are those the stock tires? If so, you do have to be within 4 - 5 pounds of what the TPMS system has been set to for minimum.
Drop them 5 lbs, front and rear, from the sticker rating. See if your light comes on. If not, drop them 5 more.
Then adjust from there. Obviously, too low will set a light but too low will also cause abnormal wear.
Old 12-04-2011, 03:12 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I ran my 08 at the sticker recommended pressures and got excellent service out of the tires.
brad
Interested in one of my mods?
Old 12-04-2011, 04:24 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
My dad draws a chalk line across his every other month or so to check his tire wear and to make sure they are wearing even
