Old 12-16-2011, 03:51 PM
CJH's Avatar
CJH CJH is offline
Trim Level: 4 x 2
Color: Charcoal
CJH is on a distinguished road
Hmm...Now you've got me thinking...
I do get a noise that I originally thought was a loose exhaust or heat shield...
Would a bad U joint make a noise similar to a loose heat shield?
Old 12-16-2011, 05:50 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I dunno, is it a squeaking noise? Squeak squeak squeak squeak squeak squeak?
Put the truck on level ground and in neutral so there's no tension on the drive train. Check the rear u-joint for rusty discoloration and wiggle the shaft side to side and up and down.
Does it clunk a little from reverse to drive or the other way around?
Old 12-20-2011, 12:27 PM
CJH's Avatar
CJH CJH is offline
Trim Level: 4 x 2
Color: Charcoal
no...none of those noises at all....
Old 12-20-2011, 06:43 PM
BadlyBent BadlyBent is offline
Vehicle: ,,,,,,,,,,,,,,,,,,,,,,
BadlyBent is on a distinguished road
i still havnt figured it out, i had the dealer check it out and they say its fine, they ran the computer and say there is no codes, but the sputter is still there, i noticed it worse the other day when i had a trailer behind me, let the truck level off and hold the gas still and it starts to sputter, let up a touch or step down a touch and it quits, all you have to do is change the rms just a tiny bit and it goes away.... very irritating
Old 12-20-2011, 07:31 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
So,,,,,Now You want "the jerks" to offer some advice????? really?
Old 12-20-2011, 09:19 PM
firelt82 firelt82 is offline
Vehicle: 2005 Dodge Ram 1500
firelt82 is on a distinguished road
Sounds to me like you are losing a cylinder for a split second. Could be one of your coil packs causing it, but I would check the boots under the coil pack and make sure none of them are cracked or broken allowing the arc from the coil pack to go to ground instead of firing the plug. I had a Jeep that had a burnt wire that did the exact same thing and it took me a month to locate it. Just had a small hole in it allowing an arc only at certain rpm anyting over or below it would not do it.
Old 12-22-2011, 12:06 AM
rex450se's Avatar
rex450se rex450se is offline
Vehicle: 2002 Dodge Ram QC
Rep:41
rex450se is on a distinguished road
I could see how the noise from my bad u-joints could sound like a loose exhaust. I would get a popping sound occasionally. Almost a metal on metal, so I could see pointing in the direction of the exhaust system, but mine was definitely the u-joints.
Victor
2002 QC, Kenwood KVT-514 indash tv, debadged,
'11 20" wheels, 5% tint, and more to come
Old 12-24-2011, 11:13 PM
RMT big horn's Avatar
RMT big horn RMT big horn is offline
Vehicle: 2003 Ram
Rep:19
RMT big horn is on a distinguished road
Default Same here
I had the same problem. Mine ended up being the coil on the number one spark plug was bad. After I replaced it the vibration and the shuttering went away. My fuel mileage increased as well. It only happened as I his around 2k rpm. I hope this works for you. Don't let it go too long.
Best of luck,
RMT
Old 12-28-2011, 10:53 PM
smiley3303 smiley3303 is offline
Vehicle: 2009 Ram 1500 Laramie Crew
Color: Stone White
smiley3303 is on a distinguished road
Originally Posted by rex450se View Post
I had a similar problem on my 02 Ram. Mine ended up being my U-Joints. I wouldn't have thought it was the cause of problem but I changed mine and I have yet to feel it again. It wasn't too bad to do myself in my driveway and I think the parts were under $30.
Victor
I've got a few pics if you would like. I tried to take some but would keep going and forget to take them at every step.
Makes sense but which ones were they? The ones on the rear drive shaft or the ones on front drive shaft?
$miley
Old 01-02-2012, 06:45 PM
I wasnt calling the PEOPLE OF this board jerks i was referring to whoever made it that had links to other helpful stuff blocked....
AND i was having a shitty day and let my mouth run a bit too much
