Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 3.7L PowerTech V6 Specific Topics
Old 11-28-2011, 10:23 AM
L.J. L.J. is offline
Vehicle: 2005 Dodge Ram 1500
L.J. is on a distinguished road
Default Lamp out light came on - help!!
I have a 2005 dodge ram ST. I was driving one day and a light came on right under the odometer that said lamp out and I figured one of my light were out so I got out and checked all the lights but they are all good. And the lights still on. Any ideas?
Old 11-28-2011, 12:50 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Double check all your lights. It usually doesn't lie. Taillights, brake lights turn signals even the cargo lights
I had it come on and both my brake lights were out, thought it was something electrical bought they both burn out simultaneously
Old 11-28-2011, 03:40 PM
kmdracer's Avatar
kmdracer kmdracer is offline
Vehicle: 03 Ram QC , 08 CSRT4
Rep:43
kmdracer is on a distinguished road
Agree, re check all your lights. The only ones that don't turn the indicator on with my truck (2003) are the factory fog lamps and interior lamps.
Old 11-28-2011, 05:49 PM
Color: Mineral Gray
Rep:177
The reverse lamps dont, atleast on our 05 and 09 they dont.
I also forgot, sometimes the circuts go bad in the taillights (white case behind the taillight, typically the passenger side I think) and will give you a lamp out message. Its more common on 03 and 04 but is none to happen on 05s. Cheap fix if that ends up being the problem
Old 11-28-2011, 07:03 PM
HemiLonestar's Avatar
Rep:274
It also seems like it starts to go off when one of the lights is close to burning out. This happened recently, drove my nuts on a road trip. Light finally burned out by the time we got home.
"Big Red"
2006 Charger R/T
Old 02-13-2012, 12:08 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Check your highbeams too. A burned high beam will trigger the light whether its in use or not.
Sure it'll suck, but it'll make you a man
Old 06-29-2012, 11:39 AM
ronnebama ronnebama is offline
Vehicle: 2002 Dodge Ram 1500
ronnebama is on a distinguished road
I had this problem about a year ago on my 2002 Ram. It would come on and then go out intermittently. I couldn't find any problems with any of the lights. Eventually, one of my tal lights went out and it came on and stayed on so I replaced the tail light bulb. The light stayed off for a few days and then came back on. Again I checked the lights and they all looked ok. I found a post somehwere that mentioned putting some grease in the bulb socket to help it seat better and so I did that and haven't had a problem since.
Old 06-29-2012, 02:52 PM
Tyler050294's Avatar
Tyler050294 Tyler050294 is offline
Vehicle: 2002 dodge ram
Trim Level: just the base
Tyler050294 is on a distinguished road
I had the same problem in my 02 ram. So i changed all my bulbs and it fixed the problem. If you cant figure anything else out that should work.
Old 06-29-2012, 05:03 PM
CaptJon CaptJon is offline
Vehicle: 2012 Ram 1500
Rep:41
CaptJon is on a distinguished road
Might pull each bulb and dab some dielectric grease in each socket.
Old 06-29-2012, 06:14 PM
Rep:274
Just had this happen to me again recently and found a bulb that didn't have a good enough connection.
"Big Red"
2006 Charger R/T
