Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 07-07-2012, 02:29 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
Your Dealer's parts dept. should have no problem ordering them for you, but most likely they do not have them in stock... The Mopar number is in this thread
So it is written ! So it shall be done!
Old 07-30-2012, 03:33 AM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
Originally Posted by AirborneSilva View Post
So what's the advantage to these plugs that I should pay almost $14 a piece for them?
You hink that's bad, try buying iridium plugs for a Mercuy Optimax outboard.....I need 6 every year, and they are $24 each.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 07-30-2012, 08:23 AM
AirborneSilva AirborneSilva is offline
Vehicle: 2013 Ram Sport
Rep:74
AirborneSilva will become famous soon enough
That does suck but at least there's not 16 of them.
2013 Ram Sport
1976 Corvette L82
Old 07-30-2012, 12:06 PM
Rep:27
The advantage, one set lasts 100 thousand miles, rather than just 30 thousand.... Most dealers charge about $200.00 or so to change them.... If doing it yourself your looking at between 3-5 hours in labor....
And from my experiance, I'm getting better gas milage and smoother engine idle
I think if you do the math, you will see the advantages
Old 09-06-2012, 08:49 AM
Pearl2012's Avatar
Pearl2012 Pearl2012 is offline
Vehicle: 2012 Ram 2500
Pearl2012 is on a distinguished road
It would be great to use these plugs as some of you have, but I have been advised that they will not fit/function in a 2012 Ram 2500 Hemi as the engine is slightly different than many of you with the Hemi in the 1500. I guess it has to do with VVT that my truck does not have. Seems a bit disconcerning, but it is what it is. Maybe someone else can chime in and provide some add'l comments.
2012 Ram 2500 ST HEMI from Colorado and a few mods
Old 09-06-2012, 10:23 AM
astroman54's Avatar
astroman54 astroman54 is offline
Rep:52
astroman54 will become famous soon enough
I'm 3000 miles away from the 30K and was advised by the dealer that the platinum plugs will work but the engine will act (in their words) "hinky" (must be one of those technical terms LOL).. AND they have seen someone who put platinum plugs in their Challenger Hemi and something with the engine went, and Chrysler denied the coverage.. Probably something not related to plugs, but seems like they take any excuse to not cover under warrentee. Since I have a 2009 with the lifetime drivetrain, I'm doing everything by their book for service just in case I have problems. Otherwise I would probably try the platinum plugs to see how they reacted. I did have one car that didn't like them so I wound up replacing them with the copper plugs shortly after. The estimate they gave me for the "Tuneup" was $500 with the copper plugs.. OUCH!
Andy
Andy
2009 Dodge Ram 1500 Sport Deep Water Blue Crew Cab Hemi 4x4
Old 09-06-2012, 10:30 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Just go with copper if you want cheap and shorter life, or iridium if you want longer life for a little more money(actually better value in the long run though). The "middle" plugs aren't worth bothering with.
It's a misconception that different plugs give more power. They all start off basically the same, then as the cheaper metals(copper) wear away you lose some performance. Iridium doesn't wear fast like copper so the performance lasts longer and stays more constant through it's life. If you dyno tested the same engine with brand new copper vs iridium plugs the power would be nearly identical. Wait 30k miles and do the same test and the iridium would hardly change but the copper would lose performance(not a ton, but noticeable).
Sean
Old 09-06-2012, 11:39 AM
TRCM's Avatar
Rep:63
Sounds like BS to me.......
Old 09-06-2012, 11:41 AM
snrusnak's Avatar
Rep:1385
^I agree, VVT has nothing to do with the plugs, it should be fine with iridiums.
Sean
Old 09-06-2012, 12:45 PM
Rep:27
First these Mopar Police Plugs are Iridium, not Platinum.
Second, unfortuneatly I don't have any additional knowledge about the Hemi's in a 2500 vs. the 1500. I would think they are the same, but I would go to different spark plug manufactures web sites, and I would compare their part numbers for a 2012 2500 and 1500 Hemi, if all their recommended part numbers are the same for both models, then you should have no problem using them... If they recommend a different plug numbers, then I wouldn't use these.... But any recommended Iridium plug should give you the same results.... Hard to believe that your 2500 Hemi is that different....
The only difference in recent Hemi's that I'm aware of, is that the bigger Hemi found in SR8 Challengers etc.... Uses a different plug than the 5.7 Hemi's
hemi 5.7, part number, plugs
