Old 11-29-2011, 07:12 PM
Kooker Kooker is offline
Vehicle: 2012 Ram Express Regular Cab
Kooker is on a distinguished road
Default Low RPM vibrations?
Just wondering if any of you guys have experienced this...
Normally around 40 mph my rpms are around 1,100-1,200. I've experienced this before in manual transmissions. If you shift into a higher gear, and have low rpms, it seems as if the car wants to stall, and it has a vibration to it. While driving my truck i get this feeling with my automatic transmission. It seems as if it wants to shift to a higher gear, but its like border line or something. When I give it a little gas the vibration goes away. Like I said this only happens around 40mph and 1,100-1,200 rpms. Anyone have any feedback on this?
De-Badge, Blacked-out Grill and Tailgate Badges, Blacked-out Headlights and Taillights, Sublime Green G2 Caliper's, Retro-Solution 35w 8,000k HIDs, LED: (Tag Lights, Reverse Lights, Interior Lights), Ground Force 2" Rear Drop, 22" KMC Slide
Old 11-29-2011, 08:39 PM
bowieknife's Avatar
bowieknife bowieknife is offline
Vehicle: 2013 Sport CC, 5.7L, 8spd
Trim Level: Sport Crew Cab
Rep:71
bowieknife will become famous soon enough
Send a message via Yahoo to bowieknife
Hi Kooker,
There's quite a few threads on this if you search under "MDS". It sounds like what you are experiencing is the engine going from 8 cyl to 4. This saves gas but sounds terrible and causes a vibration in the truck at low RPM's. You can avoid the cylinder shut down by pushing your shifter left once, and then to the right until you see a "5" on your EVIC. This disables the MDS and let's you run through all 5 gears in 8 cyl.
Hope this helps, but it is a common frustration that exists to get better MPG #'s. I personally see better local gas mileage in Manual 5 mode than in full auto. Others may disagree.
-Mike
