Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Dodge Ram Decals
Old 11-29-2011, 07:49 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
Default Replacing rockers with cam swap
Anyone replace their rockers with cam swap on hemi? My buddy said it actually makes the cam larger? Anyone have a particular type of roller rocker they have used? And putting together prices on swap, seeing I need Cam, seals, springs, rods, and maybe rockers if I want. Anything else I need to look into or price?
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 11-29-2011, 09:17 PM
mikeb33's Avatar
mikeb33 mikeb33 is offline
Vehicle: 2012 1500 CC Express 4WD
Trim Level: Crew Cab Express
Rep:14
mikeb33 is on a distinguished road
I you use a higher ratio rocker, it increases the camshaft lift. BUT if you are replacing the cam anyway, why not get the lift you want? USUALLY higher ratio rocker arms is done with a stock cam and is considered a cheaper(though less effective) solution.
You also have to be concerned with the valve to piston clearance.
2012 Express CC Black 4WD 3.92 Posi, Bedrug, Backflip G2, Cut rear springs, V6 fan mod, 180 thermo, Diablo Sport
Old 11-29-2011, 10:50 PM
Color: RED<----
Rep:15
Ya that's what I'm gonna do, cuz i looked up prices and changed my mind lol thanks for the info
Old 12-02-2011, 07:50 PM
compressor man's Avatar
compressor man compressor man is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT Sport
Color: silver
compressor man is on a distinguished road
Just get the cam you want for your needs, and change the pushrods and valve springs. You will want new OEM head gaskets, new cam and crank bolt, new head bolts, and some cheap oil for initial start up, then good full synthetic after you swap out the dirty contaminated oil. What cam are you thinking of?
FRI'D 2007 RAM SLT SPORT 4x4 in the 13's
Old 12-02-2011, 10:12 PM
Rep:3322
Just remember, the 6.1L springs and rods work and can save you some $$. The only time I'm seeing people swapping out the rockers is on the high HP LX builds where they are actually having issues with rollers wearing out and swapping to a solid rocker arm.
Old 12-03-2011, 11:00 PM
chefred112's Avatar
Rep:656
i've seen it done on 5.9's (harlan sharps) but I haven't seen any hemi rams do it...
