tonneaucovered.com
Old 11-29-2011, 09:57 PM
2011 outdoorsman 4x4 2011 outdoorsman 4x4 is offline
Vehicle: 2011 ram 1500
Color: black/ gray
2011 outdoorsman 4x4 is on a distinguished road
Default feed back
Hey, guys. Looking for a little feed back, from people with similar
equipped trucks, as mine.
i have a 2011 1500 q.c, 4x4, hemi, with 3:92 anti- spin diff, (what window sticker calls it), and 17" wheels with goodyear at/s rubber.
with the hemi, would think (with traction control off) you should be able to smoke the tires. i cant. i get two mild tire lines about 15'. thats it.
it has 2100 miles on it.
not that i am in a hurry to replace tires, but just think with almost 390 claimed h.p it should not be a problem to bring a little tire smoke.
Old 11-30-2011, 05:12 PM
CRANKYPISTOL's Avatar
CRANKYPISTOL CRANKYPISTOL is offline
Vehicle: 2011 Ram 1500
Color: Mineral Gray
Rep:13
CRANKYPISTOL is on a distinguished road
Quit tearing up your truck!!!
OK, The coil suspension helps with traction. The tires are made to grab the road. The hemi makes all its power in high RPM range. It is NOT supposed to spin.
Put it in 1st gear or 2nd, break torque it and get the rpm's up , do not let it shift into a higher gear b/c then the rpm's drop and so does the HP. If you must getmore..... you will have to go with a harder tire! Also, I hear the engine will open up more with more miles! I only have 1k on mine so far.
I work for Goodyear as a store manager! If you have any tire questions feel free to ask. If I do not know, I will find out.
Old 11-30-2011, 08:25 PM
desh desh is offline
Vehicle: 13
Color: cherry red
desh is on a distinguished road
well would like to get mine to spin but 3 rd time sent to dealer on towing cause keeps on stalling on me
Old 11-30-2011, 08:56 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
One word (I think)...... "anti-spin"
Like said, they design everything to grip, not slip. You'd have to powerbrake it to get them spinning, which is rough on the truck, especially at your mileage.
Sean
Old 11-30-2011, 09:38 PM
Color: Mineral Gray
Rep:13
Drag cars are built with a 4 link rear suspension to reduce wheel spin..... Have you looked under your truck??? No leaf springs!!!!
