Old 11-30-2011, 06:44 PM
19dodgeram99 19dodgeram99 is offline
Vehicle: 1999 dodge ram 1500
Trim Level: laramie
Color: green
19dodgeram99 is on a distinguished road
Default noob track bar help
well i just bought a 99 dodge half ton...this is my first ever DODGE!! well the guy i bought it off of said the track bar was getting bad....how do i check it....im mechanically inclined but never had a dodge or anything with a solid front axle, also i can wiggle the tie rod back and forth wich i was wondering about, it doesnt move up down but just curious. thanks for the help
Old 11-30-2011, 07:18 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
How much wiggle on the tie rod? A "little" is kinda vague. Is there a grease fitting on it, and if so, did you attempt to grease it?
There shouldn't be any more than a "little" actually I'd categorize it as a tiny bit.
Old 11-30-2011, 07:32 PM
Trim Level: laramie
Color: green
it wiggles more than a tiny bit...but with the truck jacked up the tire doesnt have any play side to side...idk how to tell you how much it wiggles. i had a 97 f150 one time and the tie rods were bad and you could grab the bar and it would separate from the ball of the tie rod, and this dont do that it just kind rolls around the ball and no i didnt try greasing them yet
Last edited by 19dodgeram99; 11-30-2011 at 07:33 PM. Reason: forgot to say something
Old 11-30-2011, 08:17 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I would pry on the bar against the frame and see if there is up and down play between the bar and the tie rod.
Any up and down play is too much.
Another way is to have someone cycle the steering and see if the bar moves around on the tie rod. Again, any noticable side to side movement is too much.
Old 11-30-2011, 08:22 PM
Trim Level: laramie
Color: green
alright ill do both of them tomorrow and i will post back here with the results on the old girl
Old 12-01-2011, 07:49 PM
Trim Level: laramie
Color: green
i had my brother turn the wheels all the way back and forth and i noticed that the passenger side outer tie rod end pops when you turn it so ill get that monday. also i grabbed the track bar and tried wiggling it and it did not move at all so i assume thats good. and i noticed the ball joints have a little movement to them so ill have to do those also
Old 12-01-2011, 09:20 PM
Vehicle: 95
Rep:1776
I just replaced my upper and lower ball joints...brand new...they move a little.
Old 12-02-2011, 12:26 AM
Trim Level: laramie
Color: green
oh really...the ones that were on my gmc didnt move at all...huh mine dont move much at all...the less i have to replace the better....if they were bad it would pop when i turn right?
Old 12-02-2011, 11:21 AM
Vehicle: 95
Rep:1776
Well mine was like steering a yacht when I ran over a slip of paper...and they did move quite a bit more. I just don't want to see you replace them just yet and still have the same amount of movement.
Old 12-03-2011, 09:02 AM
Trim Level: Fleet
Rep:47
After 138k of hard driven miles I noticed my ball joints had a "little" play in them. It was right at the factory spec of .125".
So I popped of my steering knuckles (hub bearing relacemnt gone insane) and you could take the lowers and move them quite freely.
So I replaced them....mmmmm....gotta love that "new truck" feeling!
