Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 12-03-2011, 02:56 PM
19dodgeram99 19dodgeram99 is offline
Vehicle: 1999 dodge ram 1500
Trim Level: laramie
Color: green
19dodgeram99 is on a distinguished road
ya trust me i dont want to replace stuff if i dont have to either...so they are allowed an 1/8th of an inch of play? if so that's where mine are right now.
Old 12-04-2011, 10:37 AM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
If you look at your "c" where your knuckle joins the axle you'll notice that the are not level with the ground. This is so you have preset camber/caster on your axle.
If the ball joints didn't have some movement to them, your steering would bind, or pull itself apart. So there is a certain amount of movement bult in.
However, when there needs to be measurement of freeplay that determines wear, and that is .125".
If you can detect that...dial meter is best, your joints are worn out internally and need replacement. They'll simply get sloppier as time passes.
Old 12-04-2011, 01:40 PM
Trim Level: laramie
Color: green
alright then, ill run them for a little longer and if it gets worse ill change, or actually ill take it up to the garage up the road and just have him do a precheck for a sticker that would work
