Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 12-01-2011, 08:12 PM
rickdaniel rickdaniel is offline
Vehicle: 1998 Dodge Ram 2500
Color: Blue
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
rickdaniel is on a distinguished road
Unhappy Rear End Noise
I'm not familiar with the rear end in my truck. My symptoms were seemingly identical to a problem I had with my vette. When accelerating in a turn I experienced a loud hard knock or two or three from what I think is the differential. In the vette I changed the diff fluid and included a posi-trac additive. Problem solved. Tried it with the truck and made no change. In fact shortly after that I got a horrible loud ratcheting sound even when going straight. Truck is parked now!! Axel splines maybe? Any thoughts? Thanks in advance.
Old 12-01-2011, 09:30 PM
My guess here is you have either a pinion gear or a ring gear problem.
Old 12-01-2011, 09:56 PM
Color: Blue
Is that something I can diagnose with a visual inspection removing the diff cover?
Old 12-01-2011, 10:16 PM
Yes, you can. Look for wear, broken gear teeth and if you are gonna remove the cover, look for any wobbly bearings.
Old 12-01-2011, 10:24 PM
Color: Blue
Thanks for the advise! I'll get after it on Saturday. I have no garage (the shame) and it gets dark too early to try it after work tomorrow.
Old 12-04-2011, 10:23 PM
Color: Blue
I pulled the cover off. There is no obvious damage. However there is what seems to be a lot of metal in the casing. By a lot I mean metal powder and small flakes. I pulled the axles and the splines seem to be in good condition. I think the problem might be in the differential. It is different than other differentials I've seen before. It is like a self contained differential. Any thoughts?
Old 12-04-2011, 11:55 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Check the back of the differential. Looking at the cover to the lower right of it and see if there's a "60" in the casting on the rear indicating that it's a Dana 60.
While you're down there look on the left lower (7 o'clock or so) bolt for the ratio tag.
This way it'll be easier to explain knowing which rear you have.
Old 12-05-2011, 12:03 AM
Color: Blue
I'm convinced it is a Dana 70 (unconfirmed), because that is what is supposed to be in a 2500 w/v10 or cummins+automatic according to wikipedia and dodge.info. My ID tag is too rusted to know the GRatio. I suppose I could count teeth. If I'm not mistaken it is Ring# / Pinion #. Is that correct?
Old 12-06-2011, 10:20 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
You can also find axle ratio on spec sheet in glove box or under front of hood next to latch.
Old 12-06-2011, 10:49 AM
Color: Blue
Ok, here it is. Cast on the diff case is 70-2U. Ring divided by pinion = 3.54. Axle is 32 spline. I disassembled the carrier and found the side gears worn out and a clutch steel broken. I would like to rebuild this unit but now I cant find replacement parts except at high end performance shops and they are real expensive. Ideas?
