Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Dodge Ram Decals
Old 12-01-2011, 10:32 PM
black beast black beast is offline
Vehicle: 2000 dodge ram 1500
black beast is on a distinguished road
Default turn signal questions
when i go to use my left turn signal it flashes quickly and i checked the bulbs and fuses and they are all fine. but when i use the hazzards it works fine. any suggestions?
Old 12-02-2011, 08:30 PM
I am assuming you checked both ends of the truck?
Old 12-02-2011, 09:22 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
check for a bulb shorted or relay going bad. but if its just the left only doing it take both of the left bulbs out. make sure the elements arnt touching and make sure only the bigger of the two elements light with the turn signal.
Old 12-02-2011, 09:31 PM
checked both ends and since i messed with the bulbs everything seems to be alright today. guess i wait and see. thank you i will let you know if it doesnt work
Old 12-02-2011, 10:07 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
It might be something as simple as some corrosion in the socket then. Give them a good inspection if you have to go into them again.
Old 12-02-2011, 10:09 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Hope all goes well.
Old 12-02-2011, 10:59 PM
well i looked at them again and it mught have been some corrosion because they work fine now. thank you guys im glad i joined this sight
Old 12-03-2011, 08:21 PM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
Glad they're working. I was gonna suggest that the turn signal "flasher" itself might be malfunctioning. That's happened to me before.
