Star Case Report - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Recalls and TSB's.
Old 12-02-2011, 10:12 AM
johncran johncran is offline
Vehicle: 2011 Dodge Ram
Trim Level: SLT Big Horn
johncran is on a distinguished road
Default Star Case Report
My truck now has 7K miles on it and definitely is making driveline noises that I didn't hear when it was new. Really pronounced in ECO. I want to get it to the dealer before the weather gets really bad. I want to go with a copy of the star report in hand but can't find a printable copy on the forum even using Search. Can someone provide a link to a printable copy? Since so many people are having TC problems maybe the report should be a Sticky.
Old 12-02-2011, 10:25 AM
lewisb13 lewisb13 is offline
Vehicle: 2011 Dodge Ram 1500 Big Horn
Rep:19
lewisb13 is on a distinguished road
Star Case: #S1121000005
Release Date: 6/30/11
Symptom/Vehicle Issue:
Customer indicates that the vehicle has a slight moan, drone, or rattle noise and sounds as though it is coming from the exhaust, The customer may indicate that the noise occurs under light load (1400 - 1700 engine rpm - around 40 to 60 mph)
Diagnosis:
Confirm that the noise only occurs while the torque converter is in lock-up at low speeds (around 1400 - 1700 engine RPM) at approximately 45 mph. If the noise is heard while transmission is in partial lock-up at 1400 - 1700 RPM, put the vehicle into ERS - Tow/Haul mode (deactivates MDS and torque converter in full lock-up) If the noise is unchanged, perform the following repair procedure. If the noise goes away in ERS mode, further diagnosis is required. If the noise occurs above 1700 RPM or below 1400 RPM, further diagnosis is required.
Parts Required:
AR (1) RL051167AB Kit, Torque Converter
(fits
2009 - 2011 2WD DS R/T Only)
AR (1) RL051146AB Kit, Torque Converter
(fits
2009 4.7L WK/WH/W2/XK/XH,
2009 5.7L DS/DC/DH/D1/HB/HG/WK/WH/W2/XK
2010 5.7L DS/DD/DJ/DX/WK/WH/XK/XH
2011 5.7L DS/DD/DJ/D2 Only)
AR (1) RL0512241AB Kit, Torque Converter
(fits
2008 4.7L 2WD ND/HB/HG/DR/WK/WH/XK/XH
2008 4.7L 4WD WK/WH/XK/XH
2008 5.7L 2WD/4WD DR/HB/HG/WK/WH/XK/XH
2009 4.7L 2WD ND/HB/HG/DS
2010 4.7L 2WD ND/DS/DX
2011 4.7L 2WD DS/DX/ND
2011 5.7L 2WD/4WD WD/WK/W2 Only)
Repair Procedure:
Replace the torque converter.
Follow the procedures identified in the service manual.
Old 12-02-2011, 10:26 AM
Rep:19
Cut and paste into WORD
Old 12-02-2011, 11:22 AM
11HEM1's Avatar
11HEM1 11HEM1 is offline
Vehicle: 2017 Dodge Ram 1500 Crew
Trim Level: Laramie 4X4
Color: Delmonico Red Pearlcoat
Rep:31
11HEM1 is on a distinguished road
nice thanks i wanted it too reps for that
Old 12-02-2011, 11:53 AM
Rep:19
Dont thank me! Thank RAMMIN. Appreciate it though. Good luck!
Old 12-02-2011, 12:45 PM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
Click the link below to get a picture of the star case. Credit goes to Rammin88 for originally posting this in another thread.
http://s1223.photobucket.com/albums/...927_225333.jpg
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
