Torque Converter Bulletin - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Recalls and TSB's.
Old 12-02-2011, 10:31 AM
lewisb13 lewisb13 is offline
Vehicle: 2011 Dodge Ram 1500 Big Horn
Rep:19
lewisb13 is on a distinguished road
Default Torque Converter Bulletin
Star Case: #S1121000005
Release Date: 6/30/11
Symptom/Vehicle Issue:
Customer indicates that the vehicle has a slight moan, drone, or rattle noise and sounds as though it is coming from the exhaust, The customer may indicate that the noise occurs under light load (1400 - 1700 engine rpm - around 40 to 60 mph)
Diagnosis:
Confirm that the noise only occurs while the torque converter is in lock-up at low speeds (around 1400 - 1700 engine RPM) at approximately 45 mph. If the noise is heard while transmission is in partial lock-up at 1400 - 1700 RPM, put the vehicle into ERS - Tow/Haul mode (deactivates MDS and torque converter in full lock-up) If the noise is unchanged, perform the following repair procedure. If the noise goes away in ERS mode, further diagnosis is required. If the noise occurs above 1700 RPM or below 1400 RPM, further diagnosis is required.
Parts Required:
AR (1) RL051167AB Kit, Torque Converter
(fits
2009 - 2011 2WD DS R/T Only)
AR (1) RL051146AB Kit, Torque Converter
(fits
2009 4.7L WK/WH/W2/XK/XH,
2009 5.7L DS/DC/DH/D1/HB/HG/WK/WH/W2/XK
2010 5.7L DS/DD/DJ/DX/WK/WH/XK/XH
2011 5.7L DS/DD/DJ/D2 Only)
AR (1) RL0512241AB Kit, Torque Converter
(fits
2008 4.7L 2WD ND/HB/HG/DR/WK/WH/XK/XH
2008 4.7L 4WD WK/WH/XK/XH
2008 5.7L 2WD/4WD DR/HB/HG/WK/WH/XK/XH
2009 4.7L 2WD ND/HB/HG/DS
2010 4.7L 2WD ND/DS/DX
2011 4.7L 2WD DS/DX/ND
2011 5.7L 2WD/4WD WD/WK/W2 Only)
Repair Procedure:
Replace the torque converter.
Follow the procedures identified in the service manual.
Old 12-02-2011, 12:47 PM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
Probably not a bad idea given the number of people who have experienced this problem. Up to the mods to determine if a sticky is necessary. If so, below is a link to the star case picture originally posted by Rammin88.
http://s1223.photobucket.com/albums/...927_225333.jpg
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 12-02-2011, 12:54 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:85
Turbovsix will become famous soon enough
Also, you may want to add the content from this thread to that sticky as TransEngineer had some valuable information to add that clarifies specifically why this occurs, what the side effects are, etc....
http://www.ramforumz.com/showthread.php?t=95895&page=2
Think adding a sticky on this is a good idea.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI
2017 Dodge Durango GT
2012 Jeep Grand Cherokee Limited (SOLD)
Old 12-02-2011, 03:25 PM
MADDOG MADDOG is offline
Rep:22
Moved to the TSB section.
Does the bulletin advise on what year trucks this applies to?
I do see they list years for which the T/C fits but normally they also list what year trucks the bulletin is for.
Old 07-23-2013, 10:11 PM
SupermanWV SupermanWV is offline
Vehicle: 2013 RAM 1500 4x4
Trim Level: Express Quad Cab
Color: Copperhead Pearle
SupermanWV is on a distinguished road
Is it possible this is happening to my 2013? As I've had a sound that even the dealer transmission mechanic says sounds like an exhaust rattle. To me it sounds like two washers that are loose, rattling against each other.
Clark (SupermanWV)
Old 07-24-2013, 09:14 PM
12RamSport1500's Avatar
12RamSport1500 12RamSport1500 is offline
Vehicle: 2012 Ram 1500
Color: Mineral grey
Rep:17
12RamSport1500 is on a distinguished road
I'm getting the same thing n my 2012
18" Magnaflow, S&B CAI, Diablo I-1000, Weathertechs
Old 07-24-2013, 09:20 PM
Do you have any idea what your vibration is? Could it be the torque converter? I don't have any physical vibrating in the steering wheel or anything. I just have that weird vibrating noise. And otherwise the truck seems to run and drive and change gears fine.
Clark (SupermanWV)
Old 07-25-2013, 08:38 AM
Color: Mineral grey
Rep:17
I don't have a vibration, all I get is a ratcheting sound and the tech at the dealership here said that its probably a solenoid. I'm not to sure cause it seems to be getting worse.
Old 07-25-2013, 02:19 PM
That seems like a dealership type answer. The only solenoid it could be would have to be located in the center of the vehicle. As I hear it plain as day when the window is down on either side of my truck.
Clark (SupermanWV)
Old 07-27-2013, 01:03 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
guess that explains the "hum" in my truck on the hwy.
