Recon Headlight Install Help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 12-02-2011, 11:29 AM
Scarriere's Avatar
Scarriere Scarriere is offline
Vehicle: 2112 Ram
Scarriere is on a distinguished road
Default Recon Headlight Install Help
Hey Folks!
I am wanting to install my Recon headlights but am at a bit of a standstill. The wires coming from the signal lights has THREE wires, not two. The instructions,which suck, say I should tap into the one positive wire that is solid. Well neither of the two is solid. On the drivers side there are two positives, white/green and white/blue. I can't get at my electrical tester at this moment to figure out which one to use.
Has anyone installed Recons and is able to give some advice on which wire I use?
Thank you!
p.s.
Thanks for replying earlier Brad!
Old 12-02-2011, 07:44 PM
Bordin's Avatar
Bordin Bordin is offline
Rep:516
Kind of confuse what your talking about my friend, here is my recon install. Seemed pretty simple to me???
http://www.ramforumz.com/showthread....con+Projectors
Just respond in this thread and I will keep an eye on it
Old 12-02-2011, 08:55 PM
Scarriere's Avatar
Vehicle: 2112 Ram
Thanks for Replying Bordin. I HAVE looked at your thread several times, including just now.
In the picture with the wiring in your hand, I don't see the wires for the halos/LEDS. Maybe because you've installed HIDS instead.
My truck has the quad headlights and I am supposed to splice the LED/Halos from the Recons onto the running/park light.
What I am asking is which wire do I use? There is three wires to the signal light: One black(negative) and two White (positive). The two positive are either signal OR running/park. I want to splice the Halo/LEDs onto the running/park lights.
Thank you for any info. I emailed recon but got no reply.
Old 12-02-2011, 09:16 PM
Bordin's Avatar
Rep:516
Ah I see what you mean now.
My LEDS/HALOS are wired to a seperate switch instead of my parking lights. So I can turn them on whenever I Want. I like to leave them on when I head into stores ha
Best thing to figure that out is to put your parking lights on (Selector switch) and take a voltmeter out. Get on your neutral (-) than find your positive(+) with the steady 12V. Its pretty simple, well if you have experience with DC electrical circuits and a meter of course.
Even if you want to isolate it better. leave all your lights off and shove your hazards on (or turn signal your choice) and than apply your voltmeter to your neutral (-) and your Positive (+) (it might be to fast to read) you will see it fluctuating on/off/on/off. You get the idea you DONT want to slice onto that wire
Here's my thread on my Switches for my halos/leds also
Old 12-02-2011, 11:33 PM
Scarriere's Avatar
Vehicle: 2112 Ram
Okay, I'll see if I can get at my tester.
Thanks a lot Bordin! I appreciate the advice!
Your truck looks FRICKEN AWESOME Man!
Old 12-03-2011, 10:09 AM
11Ram06Daytona 11Ram06Daytona is offline
Vehicle: 2011 Ram 2500 Mega Cab Diesel
Rep:12
11Ram06Daytona is on a distinguished road
Its sounds like you only tinker with electrical once in a blue moon. Picking up a cheap DVOM will help you greatly. You don't need anything elaborate or expensive like a fluke. I think you can normally find one for $10.00 or less...even at walmart.
Current Mods: Recon Smoked tail lights & 3rd Brake light
By the end of August: Recon Smoked Headlights & Roof Markers, 8K HID, 6" Fabtech Long Arm, Amp Research Steps, Fuel - Gauge 20" Wheels, Bakflip cover, H&S MaxxMini, MBRB Exhaust, 2 10" L7's 1500.1 Kicker amp.
Old 12-03-2011, 11:52 AM
kewlguy53403 kewlguy53403 is offline
Vehicle: 2011 Dodge Ram Sport
Rep:25
kewlguy53403 is on a distinguished road
I had to use a voltmeter as well, I had the same problem. Luckily we had one around, saved us a trip to the store!
Raptor Step & Bed Rails | K&N | BakFlip HD | Halo Proj. LIghts | Recon Brake Lights | DDM HIDs | Big Rig Lights | Night Raider Taillight Bar | Volant CAI | Magnaflow 18 | MGP Caliper Covers | Lower Billet Grill | 20% Tint | Blistein 5100 @ 2.8 | 34" Tires | Dipped Chrome
Old 12-11-2011, 08:20 PM
Scarriere's Avatar
Vehicle: 2112 Ram
Thanks to anyone who replied for the help!
I appreciate that!
Old 12-11-2011, 08:24 PM
Scarriere's Avatar
Vehicle: 2112 Ram
And one more of a side view.
Old 01-06-2012, 03:05 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Should of got spyder lights same light and cheaper and if you upgrade to hid on recon your going to have to drill out the housing
