Old 12-02-2011, 07:27 PM
KarateManAZ's Avatar
KarateManAZ KarateManAZ is offline
Vehicle: 2009 Dodge Ram
Trim Level: MagnaHEMI
Color: Deep Water Pearl Blue
Rep:120
KarateManAZ will become famous soon enoughKarateManAZ will become famous soon enough
Default Magna Charger
MagnaCharger Build!
Parts:
Magna Charger 6psi Kit
ATS Built Transmission
Inertia Motorsports ported heads and internals
Inertia Motorsports custom "blower cam"
Fastman over sized ported TB
EBS Sport rotors
EBS kevlar brakes
SUPER Excited. Install will be in the next couple of weeks!
2009 Ram 1500 Crew Cab - Deep Water Pearl Blue
2/4 Drop, 0212353 Retro Shop Projector Retrofit w/ custom paint, Jet 180 T-Stat, AR LT Headers, 545rfe w/ deep pan,
Inertia Cam, Edge Triple Disk, Magnaflow 18"
Oh Yeah its a MagnaHEMI 12.2@109
Sounds like an awesome build!!!
Old 12-02-2011, 08:59 PM
I push the skinny pedal
Rep:3277
I would look at a true 85mm throttlebody over the fastman, it's just a ported OEM one, so the blade size is the same as stock. If you're going forced induction then you should look at a cast 85mm that has a true usable 85mm blade diameter, even if they are more money. If you're dropping the cash for a supercharger, you can probably spend the extra $200 for a throttlebody that will give you better gains than a ported job.
Modern Muscle, Arrington, and BBK all make a true 85mm (ok, they might be ~84.5mm in some cases)
Kurtis
Old 12-02-2011, 09:53 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Can't wait to see it done! I talked to Stu the other week about a cam safe for a supercharger later
Old 12-02-2011, 10:42 PM
Blue Streak Blue Streak is offline
Vehicle: 2011 Ram 1500 Sport 4x4
Rep:63
Blue Streak will become famous soon enough
Post some pics of the build!
Old 12-02-2011, 11:45 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
A build without pix is like a Ram without a driver.
Please have a driver for the Ram!
brad
Interested in one of my mods?
Old 12-11-2011, 08:53 PM
RamLover's Avatar
RamLover RamLover is offline
Vehicle: 09 1500(Dodge Ram.. obviously)
Color: Mineral Gray
Rep:58
RamLover will become famous soon enough
SICK DUDE!!! Cant wait to see some progress with your build and what you're gonna be pullin on the dyno when yer done!
TOO MUCH IS JUST ENOUGH!!
