Front seats making noise. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-04-2011, 01:18 PM
nfllover911 nfllover911 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Longhorn
Color: Sagebrush
Rep:17
nfllover911 is on a distinguished road
Default Front seats making noise.
My driver seat and passenger seat make this creaking sound when people are sitting in them. Also the passenger seat rattles a tiny tiny bit when no one sits in it but it can really be a pain in the a$$. Anyone having these problems? The truck is brand new only 4k miles on it.
Old 12-04-2011, 02:14 PM
Gio310's Avatar
Gio310 Gio310 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:13
Gio310 is on a distinguished road
I had the same problem with my passenger side seat. When I would hit a bump or uneven surface it would creek and rattle. I tightened down the two front bolts that hold down the pass seat. No more noise.
Old 12-04-2011, 02:18 PM
TerrysRam's Avatar
TerrysRam TerrysRam is offline
Vehicle: 2011 RAM 1500 4x4 SLT
Trim Level: Outdoorsman
Rep:16
TerrysRam is on a distinguished road
You could try what Gio310 said or I'd suggest getting a good exorcist and see if maybe somebody is haunting your truck. But brand new? Maybe an accident in the plant?
Sorry goofy mood today.
Rain-X Latitude wipers; Volant CAI - with ram air tubing; custom y pipe; Xlerator racing muffler; cats delete HemiFever custom Diablo tune; Line-X; Putco SilverLux LED headlamps; Putco Luminix LED fog lamps; Bilsteins 5100's all around, leveled up front; BFG AT KO 2's; KMC XD Battalion rims
Old 12-04-2011, 05:02 PM
moparmann moparmann is offline
Vehicle: 2011 dodge ram
moparmann is on a distinguished road
Default front seat
My truck has 2500 miles, front seat is pretty squeeky as well. Guess I'll try tightening the mounting bolts
Old 12-04-2011, 05:48 PM
Color: Sagebrush
Rep:17
Tightened them and its still making noise. I don't think it's the bottom of the seat I think its the back part of the seat. When I put pressure on the back seat say with my back pushing on the seat that is when it will make noise. I am going to call my service department tomorrow morning.
Old 12-04-2011, 08:19 PM
2011CanadianRam 2011CanadianRam is offline
Vehicle: 2011 Ram
2011CanadianRam is on a distinguished road
My passenger seat just started to do it too. Not too bad when someone isn't in it but really squeaks when someone sits in it.
2011 Mineral Grey Sport w/Performance Hood.
Old 12-04-2011, 09:22 PM
53fireman 53fireman is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman RAMBOX
53fireman is on a distinguished road
I had the same issue with the passenger seat and the cause was an exhaust heat shield bolt under the passenger seat. It sticks straight down and rubs on the frame when someone's in the seat. Dealer grinded off the tip of the bolt, and no more noise. It took them a LONG time to figure it out...
Old 12-04-2011, 10:26 PM
RPD RPD is offline
Trim Level: Sport Crewcab 4x4
RPD is on a distinguished road
I had the squeaky seats up front on my 2011 sport. I took it in and the dealer had to tighten some nuts on the seat cushion this required them to remove the upholstry as I was told by them. It can be PITA take it back they will fix it under your warranty.
Old 12-05-2011, 12:30 AM
Dave532 Dave532 is offline
Vehicle: 2014 2500 Ram
Color: Cherry Red
Rep:18
Dave532 is on a distinguished road
My drivers seat was squeaking incessantly on my 2011 2500 with 3500 miles. Dealer warrantied without issue. Tech description:
"I lubed the driver's seat pivots and track"
-Dave 532
Old 12-05-2011, 12:37 AM
blackpearldodge's Avatar
blackpearldodge blackpearldodge is offline
Vehicle: 2015 Crew Cab 1500 Sport 4x4
Rep:19
blackpearldodge is on a distinguished road
My Sport had a similar problem earlier this year. Took it to the dealership for repair. They had to loosen and then re-torque the bolts that hold down the seat..while somebody was sitting in the seat. Never had another squeak since. The noise was very very irritating. I would also get the noise when I pushed on the back of the seat (wiggle left to right).
It was a simple case of loosening and then re-torquing the seat bolts!
Oh... the dealership told me the cause of the squeak was due to a piece of plastic wrapping (wrap that is on gum containers) was wedged between the seat bracket and floor. Huh!? He showed me the plastic, but I didn't believe it then and I don't believe it now. BTW he did not write that on the work order. Just that the tech re-torqued the bolts. LOL
Once you have Black you'll never go back! Hmmmm.....well... now that isn't quite true. I went back to WHITE!
Sport Performance Hood, OEM Mud Flaps, Factory Spray-in Bed Liner, CREE MK-R LED Fog Lights
